displaying posts 1 to 25 of 33
Author Subject: Cam timing out
zac
Was taking the car for a good blast the other night and it suddenly decided to run like it was on 3 cylinders. Sounded like an Impreza.
I figured it was a coil pack, although it was quite abrupt in nature and would not run without cutting out unless I kept the revs up a bit; to my knowledge, it should still run at idle with a duff coil pack, albeit sounding a bit lumpy.
So I limped about a mile home, and have today discovered that it's not a coil pack.
Is it possible that the timing belt has slipped a bit? I'd like to check the cam timing, but it's something I've never done so I'm not too sure what exactly I'm looking for!
Any help would be massively appreciated.
Hit the limiter in 6th gear at 169mph (GPS - TomTom on the German autobahn). Still pulling like a train too. Cheers
- Phase 3 GTi-6 (409hp 'charged weekend toy)
- Phase 2.5 Rallye (daily driver)
R.I.P Pete Sims
Posted 21st Mar 2010 at 18:42
james_gti6
might help
if i dont see you in the mattress il see you in the spring
Posted 20th Mar 2010 at 15:57
mabgti
NV motors
i had a similar issue... turned out to be a a leak on manifold.. tightening the bolts up to torque sorted it Yes
Team Supercharged Gti-6
NV Motorsport
Automotive Performance Tuning
0121 448 7515
ECU Remapping/ DPF removal
www.nvmotorsport.com
Facebook Page
Project S6
Posted 20th Mar 2010 at 18:57
zac
I'll have a look Mab, but it doesn't sound right to me. No
Let's just say I was stretching her legs and all of a sudden it went. Struggles to start and just runs absolutely terribly if it does start, shakes like a shitting dog for a few seconds and then stalls.
R.I.P Pete Sims
Posted 20th Mar 2010 at 19:50
chris with a pug
Just whip off the cover and see if all the holes line up, but just bare in mind that if your timing was advanced it wont line up.
Posted 20th Mar 2010 at 20:00
zac
There are a couple of manifold bolts loose.
However, the cam timing definitely doesn't quite line up. Sad
I appear to have different pullies compared with the ones shown in the FAQ though; do later engines have a different pulley design?
Got a mate coming up to have a gander as I don't know enough about timing to risk damaging the engine.
R.I.P Pete Sims
Posted 21st Mar 2010 at 18:31
guess you have a single 18mm bolt in the middle?
like this;
Posted 21st Mar 2010 at 18:51
fletch
Track Head
Two different designs of pulley Zac, seen a couple of the older style break before, so I think your deisng is preferable. How far out is the timing?
Posted 21st Mar 2010 at 19:47
zac
No mate they're not the same as that, the inlet pulley is actually different from the exhaust pulley. Inlet has a big circular hole on one of the 'spokes'. Maybe an older style engine has been used for the rebuild?
Fletch, it's hard to tell as I've not fully taken the cover off, just the top bolts so I can prize it open to look. But around 10-20 degrees I'd say.
R.I.P Pete Sims
Posted 21st Mar 2010 at 20:15
Alloy bottom pulley?
sounds like this type of pulley then
Posted 21st Mar 2010 at 20:26
zac
It's not that type of pulley either! Are there any other types? LOL:
R.I.P Pete Sims
Posted 21st Mar 2010 at 20:30
not o.e that I ever remember seeing nope LOL
have you got an alloy bottom pulley on there? how do you know that the cam is out? tried a pin into it?
Posted 21st Mar 2010 at 20:38
Could be the HG gone between two cylinders - sounds very familiar. Have you comp tested it?
I thought it was a coilpack and it sounded like a subaru / on 3 cylinders. Don't run it until you comp test it as you might burn a channel in the head - can be ally welded and skimmed but its a pain in the arse.
Posted 21st Mar 2010 at 20:45
zac
Standard crank pulley. Can tell they're out just by looking at them; in all the diagrams I've looked at you can see that they're nice and symmetrical..just look slightly out of sync'. I've got a couple of photos but they aren't the best.
Adam, I'm not going to start it up until I'm 100% that the timing is okay. Don't think it's the HG but will bear it in mind.
R.I.P Pete Sims
Posted 21st Mar 2010 at 20:49
I wouldn't trust the standard crank pulley Thumbs up
sods law, there is a 3rd type of pulley, found this;
the engine RichW built for Bininoz
Posted 21st Mar 2010 at 20:47
zac
That's the kiddy! Except mine's on the inlet...not that it makes a difference. What's up with the standard crank pulley then?
R.I.P Pete Sims
Posted 21st Mar 2010 at 21:18
The rubber damper can come loose causing the timing hole to be out.
Posted 21st Mar 2010 at 22:09
mabgti
NV motors
Zac who built your engine?
was it custom mapped at waynes? as i presume he'd alter the timing a bitYes
NV Motorsport
0121 448 7515
Facebook Page
Project S6
Posted 21st Mar 2010 at 22:25
Mine were both out if you looked at them as they'd been advanced - i'd be very surprised if Wayne didn't move them about a tad.
How much out are they?
Posted 22nd Mar 2010 at 01:04
rich_w
Zac,
Don't be suprised if the timing holes in the cam sprockets don't line up with the holes in the head - it more than likely that Wayne had adjusted them.
I would check the timing, if it's massively out it could be the issue - but they don't normally slip, particularly when done up properly. And Wayne is the sort of person to do things up properly...
I would then take the plugs out and see what they look like, then perhaps look at a compression test. It's also wortth checking it's not something simple like a multi-plug on an injector or coil.
Smile
Contact Details:
07732 822546
Posted 22nd Mar 2010 at 18:01
zac
Cheers lads.
Wayne did adjust the timing slightly but didn't say exactly what he'd done.
I'll make sure the timing is okay before I do a compression test as I obviously don't want to keep cranking it if that timing's fubarred. Will check the plugs too.
R.I.P Pete Sims
Posted 22nd Mar 2010 at 19:35
xploit
What a mare LOL:
Lads i need a decent resource on timing this engine up properly if it is indeed wrong.
Best dig out my comp tester then!
Its definatly a leak on the engine or the timing though from my initial thoughts, it wont idle and sounds really bad when its forced to run.
What other control devices are there that could cause a bad or non idle? Names, jobs and likely hood of failure if poss.
Thanks, Dan.
Team Evo, because they're the tits.
Posted 22nd Mar 2010 at 22:30
zac
http://www.306gti6.com/forum/showthread.php?id=64509&page=1
Have a gander in there Dan...
Oh, and I think I already have your comp' tester. Laugh
R.I.P Pete Sims
Posted 22nd Mar 2010 at 22:54
xploit
That DIY cambelt guide looks helpful enough.
few Q's for anyone to answer please.
Harmonic balancer, whats this when its at home?
Whats the deal with this crank pulley? Is it two parts, how does that work?
Looks overally complicated as usual LOL:
I guess i need to fetch that comp tester from Big Al?
Posted 22nd Mar 2010 at 23:23
smegal
It's a rubber outer on a metal inner with a timing hole in it, the rubber part can slip making the timing hole not line up.
Ex SC-6
Now in a Megane R26
Posted 22nd Mar 2010 at 23:35
