clicky
need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets.
displaying posts 26 to 33 of 33
Pages (2): 1 [2]
| Author | Subject: Cam timing out |
xploit wrote: Harmonic balancer, whats this when its at home? clicky ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
xploit
Newbie Location: Notts/Leeds Registered: 22 Mar 2010 Posts: 33 Status: Offline |
welshpug! wrote: Thanks for that, very clever link thing! To clarify from limited knowledge of these engines, if this rubber bond on this crankshaft pulley does deteriorate and the pulley 'slips' it cant pull the crankshaft out of time can it? Just pull the timing mark out of alignment making it a PIA or impossible to re-time. I gather the outer part of the pulley is this 'harmonic balancer' ? Clever! Is the french crank abit prone to breaking then? or has in previous evolutions of this engine? ________________________________________ Team Evo, because they're the tits. |
yep you're spot on there, it wont actually place the timing out, but if its used to check or set the timing it will be incorrect if its damaged.total failures of the pulley on this engine is not known of though they do have this issue of slipping round, its very common for a similar item on the HDI engines to collapse and take the timing belt out ![]() I dont think its an issue to have a solid alloy item on there, but they do use them to iron out any harsh frequencies that might cause issues. Rich Walker (guy who started this Rotrex GTI6 Revolution) does alloy solid billet replacements which eliminate this problem (they're also nice and bling and a lot lighter) ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
xploit
welshpug! wrote: yep you're spot on there, it wont actually place the timing out, but if its used to check or set the timing it will be incorrect if its damaged. total failures of the pulley on this engine is not known of though they do have this issue of slipping round, its very common for a similar item on the HDI engines to collapse and take the timing belt out ![]() I dont think its an issue to have a solid alloy item on there, but they do use them to iron out any harsh frequencies that might cause issues. Rich Walker (guy who started this Rotrex GTI6 Revolution) does alloy solid billet replacements which eliminate this problem (they're also nice and bling and a lot lighter) I have seen them on his website yes, when i was looking for pics of his swirl pots while trying to sort Zacs out, another mini mare : The pulleys look extra trick, up my street indeed!Not really looking forward to this but needs must, i imagine Zacs crank pulley would of been new with the engine so shouldnt be buggered... He says! Thanks for the help guys! ________________________________________ Team Evo, because they're the tits. |
xploit
Broken spark plug. Tips missing so hopefully it got blown clean out the cylinder and past valve seat!!!________________________________________ Team Evo, because they're the tits. |
EEP!________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
mechanical_repairs
Hopefully that will be the kiddy then and the lump will be ok!I have my fingers crossed, i bet you looked at all the more tricky bits to check before the plugs? Always the way. Carl ________________________________________ C.G.Cars of Leicester, Peugeot/Citroen/Renault specialist Tel: 01162 624498/07799 405184 WWW.CGCARSLEICESTER.CO.UK36 narborough road south, Leicester LE3 2fn MOT station now open, tests £35 with a free retest. Recovery available with a recovery unit, for those not so local jobs Also offer the loan of a free courtesy car 306 dturbo |
zac
Seasoned Pro Location: Leeds city centre Registered: 26 Dec 2005 Posts: 2,627 Status: Offline |
Well I did the coilpacks a few nights ago, and only checked the plug on cylinder number 2 as it was midnight and absolutely p*ssing it down...made the mrs hold an umbrella for me. ![]() ________________________________________ Hit the limiter in 6th gear at 169mph (GPS - TomTom on the German autobahn). Still pulling like a train too. Cheers- Phase 3 GTi-6 (409hp 'charged weekend toy) - Phase 2.5 Rallye (daily driver) R.I.P Pete Sims |
Pages (2): 1 [2]
