displaying posts 26 to 42 of 42
Pages (2): 1 [2]
Author Subject: hydraulic to cable help?
bobdylan_55
aye but that seems a bit dodgy, its like that on the be1 and they sometimes fall out lol.
just been speaking to my dad as hes top notch engineer and says he will get me some spring dowels tommorow for the pivots, and then i just need to knock the rest up at uni on monday from some steel billet Smile
o btw, its designed to bolt to the 2 holes that are left in the casing where the hydraulic arm went in, so 2 bolts into cast casing will probably be ok id have thought?
309 GTi6-T
Posted 12th Mar 2010 at 22:15
smegal
Surely it would be easier to make something like the assembly in the pic I posted than to custom make a manual attachment for the box?
Ex SC-6
Now in a Megane R26
Posted 12th Mar 2010 at 22:14
smegal
I will give you a BE3 clutch fork to adapt, and if it helps I will help you make the assembly.
Ex SC-6
Now in a Megane R26
Posted 12th Mar 2010 at 22:16
bobdylan_55
the actual assembly maybe, but i dont really understand how they have done that in that diagram. looks like they have just used a wilwood cylinder or something so would require hydraulics anyway..
309 GTi6-T
Posted 12th Mar 2010 at 22:17
bobdylan_55
ive got a fork from a xsara vts which looks like it might do, if not ill give you a shout Smile when you abouts at uni?
309 GTi6-T
Posted 12th Mar 2010 at 22:18
smegal
I'm in most days. It literally is a wilwood cylinder, some pipework and connected to the peugoet piston. Admittedly I have no idea how you would bleed that system but that seems to be the easiest method. Surely someone sells some flexi hose that you just bolt to each part.
IIRC Carl's rallye has this set up on it. (I know I've seen a pic of it somewhere)
Ex SC-6
Now in a Megane R26
Posted 12th Mar 2010 at 22:22
bobdylan_55
wilwood sounds pricey lol i dont have a working piston either, just some bodge i got from scrapy
309 GTi6-T
Posted 12th Mar 2010 at 22:31
wilwood cylinders aren't expensive, and a BE3 clutch fork will not fit.
Posted 12th Mar 2010 at 23:31
jonnie205
do the job properly, why in gods name do you want a cable and hydraulic. Its no easier by the time it keeps breaking, bending, flexing, falling to bits and looking bloody horrible Crazy
Posted 12th Mar 2010 at 23:35
smegal
Post #35
Surely a BE3 fork will quite happily mate to a BE3 cable? It was for the adapter not the actual box [extended by the correct length to depress the wilwood cylinder].
Ex SC-6
Now in a Megane R26
Posted 12th Mar 2010 at 23:48
Post #36
cable doesnt attach to the fork, it attaches to the lever arm.
but like Jonnie said, if you have the time I would go for the hydraulic setup, far simpler than trying to calculate all the different lever ratios and trying to make something strong enough, AND make it fit tidily.
Posted 12th Mar 2010 at 23:59
bobdylan_55
Post #37
ok so im going to try and do it with hydraulics, my bro recons best way to go is put a pull type cylinder on the pedal?
309 GTi6-T
Posted 13th Mar 2010 at 17:24
Post #38
depends how much space you have, pull type may place it too low, push type if there's space will sit up above the pivot.
Posted 13th Mar 2010 at 17:35
bobdylan_55
Post #39
think im gonna get floor mounted single pedal from tweeks for
309 GTi6-T
Posted 13th Mar 2010 at 20:48
Post #40
is there enough space for that given that they sit right against the bulkhead?
Posted 13th Mar 2010 at 21:17
bobdylan_55
Post #41
not sure, as its a bolt in pedal i can move it fowards a little bit, and if still isnt enough room ill have to cut a hole in bulkhead and stick it through and seal round the edge or something.
309 GTi6-T
Posted 14th Mar 2010 at 00:18
Post #42
Hi bobdylan,
You can easily do it (well with about 10 hours tinkering) with a 205 BE3 arm and cable, using the standard pedal. Mine is now working perfectly.
Basically you pin the clutch bearing lever to the rod, make the rod a bit longer and punch a hole in the top nylon bush so it sticks out. Weld an arm on to that and then fix the end of the clutch cable to the engine, so the cable outer moves the clutch arm.
I've just tried to take a decent photo but its not happening at the moment - too many things in the way...
Posted 14th Mar 2010 at 21:08
Pages (2): 1 [2]
