displaying posts 1 to 25 of 42
Author Subject: hydraulic to cable help?
bobdylan_55
how can i convert the hydraulic fork on ml5t gearboxes to cable? ive been looking for ages and cant see any logical way of doing it...
you cant just change the arm over because it doesnt have an arm, its hydraulic so works off a cylinder and hoses etc.
cheers
309 GTi6-T
Posted 12th Mar 2010 at 17:02
smegal
Can you not just drive a hydraulic master cylinder with the cable?
I'll just see if I can find the pic.
Ex SC-6
Now in a Megane R26
Posted 12th Mar 2010 at 17:04
bobdylan_55
this is what i have at the moment. I cant see how if would push the bearing as such in to disengage it?
309 GTi6-T
Posted 12th Mar 2010 at 17:12
monty-69
Il 2nd that, convert to hydaulic for a lighter, short throw clutch. Look on 205v6.com for ideasMellow
Posted 12th Mar 2010 at 17:59
smegal
Ex SC-6
Now in a Megane R26
Posted 12th Mar 2010 at 19:02
bobdylan_55
that doesnt make sense. The end thats bolted to the cable arm is the end that pushes the fork isnt it?
im struggling to see how the fork can be pushed in the right direction to push the release bearing into the pressure plate?
It needs to go like this (up at bearing end, hence pushing bearing onto the pressure plate, and down at the other end.
i cant see how this is achieved when the hydraulic thing doesnt even connect to it (even originally) it just sits in a ball sort of thing...
309 GTi6-T
Posted 12th Mar 2010 at 20:05
its a pull clutch....
Posted 12th Mar 2010 at 20:22
bobdylan_55
so it works by pulling the bearing away from the pressure plate? if so thats great Smile
how do pull clutches work btw? confusing :s
309 GTi6-T
Posted 12th Mar 2010 at 20:23
jonnie205
the best way to go is convert the pedal box to hydraulic, too many parts to flex, break and go wrong combining the both. I converted a mk2 escort pedal box from cable to hydralic and it wernt to bad to do. If you have to fabricate parts anyway then why not fabricate the pedal box to make it all hydralic
Posted 12th Mar 2010 at 20:27
bobdylan_55
because i hate welding lol.
309 GTi6-T
Posted 12th Mar 2010 at 20:29
jonnie205
whip the pedal box out of the car and have a look, there will be plenty of fabbies that will have a look at it for you, best to rob the master cylinder from the 406 too and have a look if you can use that
Posted 12th Mar 2010 at 20:33
Laugh my ass off
you just said how they work LOL
unfortunately there's feck all space to do it with the turbo engine in there as IIRC the Turbo sits pretty damn close to the brake servo as it is, the outlet of the turbo I think is right where you'd want to put a Clutch Master Cylinder Doh
unless you mount the master cylinder in the cabin working from the top part of the pedal.
check my fecking awesome Photobucket skillz
LOL
Posted 12th Mar 2010 at 20:48
bobdylan_55
i hate hydraulics aswell Razz
i know it pulls the bearing out, but i cant see how that disengages the clutch?
could i not simply rig up an arm to the gearbox casing that accepts a cable type, then connect that to a pole which pushes the fork down hence pulling the bearing away?
ill do a paint sketch in a min and show wat i mean.
309 GTi6-T
Posted 12th Mar 2010 at 20:54
easier to pin the clutch fork to the shaft, then extend the shaft out through the top bush and make an arm to go on the top.
then attach the inner cable to the engine and the outer cable to the lever to work jsut like a gti6 pull clutch.
Posted 12th Mar 2010 at 21:00
jonnie205
adapt it in the cabin is the way to go like the diagram above. That is the propper solution
Posted 12th Mar 2010 at 21:03
that just came to me now, can't think why nobody has done it yet either LOL
easy enough to get some high pressure small bore hydraulic hose made up to suit.
Posted 12th Mar 2010 at 21:05
bobdylan_55
ive already thought of that, but unfortunately theres no space because of the cable gear arms which are near enough directly over where the shaft would be extended out Sad
in cabin way would be too much effort and moneys. i want a cheap solution Wink
check this mofos
309 GTi6-T
Posted 12th Mar 2010 at 21:07
jonnie205
no chance, there is a serious amount of force required to operate a clutch and that will flex and break, why not concentrate on doing the job properly. If you ae going to the lengths of fitting that box why are you falling short on the clutch side of it
Posted 12th Mar 2010 at 21:15
maybe Hmm pretty much how a BE1 box works actually LOL
oh, and as for the cable linmkages, there is enough room, that's how AdamB and Goliath sorted theirs, adam's needs a little more perfecting, not sure about Georges one.
Posted 12th Mar 2010 at 21:16
bobdylan_55
because i really cant be arsed anymore but i have to for my uni course otherwise i get a big fat fail Smile
its more because my project is the engine, not the gearbox and i really want to get moving along and get the engine running as ive only got until may..
309 GTi6-T
bobdylan_55
yeah thats where i got the idea from, i have a be1 sitting on the floor next to it lol.
i dont see why it wouldnt work if its all bolted on well and made from decent material etc. the be1 boxes are much more flimsy looking and still work fine.
309 GTi6-T
Posted 12th Mar 2010 at 21:18
they do have a much weaker pressure plate than the ML5 though.
Posted 12th Mar 2010 at 21:28
bobdylan_55
agreed, but if i reinforce it enough will it see me good until i have time to properly set it up using hydraulics etc? its only got to last a short trip down a38 and a rolling road session to prove the power output then it can stay on drive until i have time to fig around with hydraulics.
309 GTi6-T
Posted 12th Mar 2010 at 21:30
bobdylan_55
recon this would stand up to much? bolted to the gearbox casing in 2 places.
309 GTi6-T
Posted 12th Mar 2010 at 21:57
doesnt need the extra pivot on the end, just a cup for the rod to sit in Smile
Posted 12th Mar 2010 at 22:05
