| Author | Subject: KW V2 Basic |
akcz
Newbie Location: Czech Republic Registered: 16 Apr 2004 Posts: 10 Status: Offline |
Does anyone know if the rear shock adjustable stiffness (rebound) as a front? |
Just compression I believe no rebound |
akcz
Picakcz has attached the following image: |
smegal
Oooh they have different rears now. Mine are koni branded ones.________________________________________ Ex SC-6Now in a Megane R26 |
akcz
Inox version are the same rears? |
smegal
No idea. My kit is a few years old.In fact it is bigbadbowen's old kit. ________________________________________ Ex SC-6Now in a Megane R26 |
dhampton
Seasoned Pro Location: Brighton Registered: 21 May 2003 Posts: 7,211 Status: Offline |
Our KW variant 2's bought last year were yellow koni rear shocks. What's "V2 basic"?________________________________________ Clio 182 FF |
akcz
http://www.kw-suspensions.eu/int/kw_variant_2.phpI thought the only difference is material. V2 is adjustable height/rebound but my kit contains front rebound adjustable.. rear not adjustable |
smegal
I think if you push it all the way in you can turn it to adjust it or something.________________________________________ Ex SC-6Now in a Megane R26 |
dhampton
Pull the plastic cover back, compress the shock fully, press and hold the small metal button (button on the side of the shick under the plastic cover), twist the shock - thats how it works for our kit anyway.________________________________________ Clio 182 FF |
dragoon
Seasoned Pro Location: Ghent - Belgium Registered: 30 Dec 2008 Posts: 1,071 Status: Offline |
jep, same here, but as smegal I've had the older kit with adjustable koni rears (and a kw sticker :p )________________________________________ Team WheelwhoreTeam Limited Edition Astor 306 Francorchamps RIP Virtual Blue 208 GTi quote: I this place. So many illiterate deluded fool's acting 'ard . . . and so many literate intelligent people to rip them apart and knock them back down again . . . ahh ![]() |
akcz
dhampton wrote: Pull the plastic cover back, compress the shock fully, press and hold the small metal button (button on the side of the shick under the plastic cover), twist the shock - thats how it works for our kit anyway. Pic ![]() I tried Koni adjustment procedures but unsuccessful.. http://www.koni.com/193.html akcz has attached the following image: |
You are kidding me about the rears being the same as Koni yellows? For that much money? Bloody hell!________________________________________ Nothing to see here |
jimmy_boy
Senior User Location: Christchurch Registered: 09 Jun 2003 Posts: 14,752 Status: Offline |
akcz wrote: dhampton wrote: Pull the plastic cover back, compress the shock fully, press and hold the small metal button (button on the side of the shick under the plastic cover), twist the shock - thats how it works for our kit anyway. Pic ![]() I tried Koni adjustment procedures but unsuccessful.. http://www.koni.com/193.html Just as it shows on your picture.. ![]() There is the button you have to press AFTER you fully compress the damper. Then twist the whole thing to adjust stiffness. adam b wrote: You are kidding me about the rears being the same as Koni yellows? For that much money? Bloody hell! What rear dampers come with the AST kit? ________________________________________ GTI-6 & RallyeRallye gets sideways in the wet at Snetterton |
AST ones ![]() ![]() ________________________________________ Nothing to see here |
jimmy_boy
Look nice! Are they adjustable?Although I couldn't be happier with the arse of our Rallye. Perhaps that's more to do with the solid beam mounts, 25mm TB's and Hybrid ARB ![]() ________________________________________ GTI-6 & RallyeRallye gets sideways in the wet at Snetterton |
Some of the Koni buttons only adjust on full extension - that kept my cousin busy for a while trying to work out why they wouldn't adjust on his 106 ![]() ^^Yes the AST are adjustable. ________________________________________ - Bespoke rollcages/additions/adjustments. Half cages right up to complete custom spaceframes - MSA/FIA spec, CDS, ROPT, T45, etc - PM meEmail me! Custom-made polybushes available - need an odd size or fitment? - anything from batch work to one-off pieces. |
Adjustable and can be completely tailored to your needs - same as Phil's in that respect (although minus quite a few other tricksy bits) ![]() ________________________________________ Nothing to see here |
akcz
jimmy_boy wrote: Just as it shows on your picture.. There is the button you have to press AFTER you fully compress the damper. Then twist the whole thing to adjust stiffness. I see.. but there is not button on rear dampers |
akcz
V2 Basicakcz has attached the following image: |
pete_rallye
Seasoned Pro Location: Yorkshire Registered: 12 Dec 2002 Posts: 5,253 Status: Offline |
I don't think they are KW V2's in the pic, maybe V1's which are not adjustable. KW V2's, you don't fully compress them. You just push the button down and turn the strut until the button pushes right in, you'll feel it drop further in. Then when the button is right in you adjust the shock to suit. Theres only 3 settings though, its not infinetly adjustable like the fronts. Oh, and there only Koni casings, they have KW internals apparently, doubt theres much difference though. ________________________________________ Oulton Park in a BTCC 306 vid 1Oulton Park in a BTCC 306 vid 2 Lap of the 'ring |
jimmy_boy
Ah that's right I now remember f*cking about for ages trying to fully compress them! Whilest pushing a button and twisting I nearly broke my own arm and Dave's in the process ![]() That's all that's stuck in my brain - completely forgot the fact that we never needed to fully compress them ![]() ________________________________________ GTI-6 & RallyeRallye gets sideways in the wet at Snetterton |
akcz
Front: 700 1001 (BVB653 and BVB564)Rear: 700 1101 (BVB 634) All packed in box as KW V2 Basic ![]() akcz has attached the following image: |
akcz
Boxakcz has attached the following image: |
They have changed the V2's since I bought mine ? They have rebound adjustment on the front now I think instead of compression ? and the rears are there own casings but prob just the same internals as before ? Those in the pic are def V2 |
