Peugeot 306 GTi 6BMW 320 td compact M-sport
1967 Mini Cooper
1990 Jaguar XJR 4.0
| Author | Subject: Rocker Breather pipes |
mark-house
Seasoned Pro Location: Bury St Edmunds Registered: 07 Apr 2009 Posts: 1,096 Status: Offline |
Just a quick question. What effect would it have on the running of the enigne if the two breather hoses on the top right hand side of the rocker were blocked? ________________________________________ Peugeot 306 GTi 6BMW 320 td compact M-sport 1967 Mini Cooper 1990 Jaguar XJR 4.0 |
It'd probably blow the dipstick out of the tube.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
jeffers
Forum AdminLocation: Leeds Registered: 14 Dec 2003 Posts: 3,702 Status: Offline |
welshpug! wrote: It'd probably blow the dipstick out of the tube. Almost definately! ________________________________________ Team Running Engine again!Team Negative Camber! My Budget track engine build thread! Now appearing at a Trackday near you!! |
mark-house
Cool that would be fun to see! what about if there was a partial blockage? could it cause idle/rev faults similar to those from a failing MAP/ICV?________________________________________ Peugeot 306 GTi 6BMW 320 td compact M-sport 1967 Mini Cooper 1990 Jaguar XJR 4.0 |
matt306gti
Newbie Location: Bournemouth Registered: 10 Feb 2010 Posts: 41 Status: Offline |
Highly likely..The rocker breather system is there to do 2 jobs. Remove oil and water from the hot air at the top of the head and secondly to relieve positive crankcase air pressure iirc It also stops backfires into the inlet manifold from igniting crank case gasses, which you really dont want happening!By pulling these gasses from the crankcase it will also prolong the life of your engine oil, which is a nice little bonus ![]() On idle it basically sucks the bad vapours out of the engine so if it is partially blocked it will almost definately be causing issues. Scrap the old pipes and stick a catch tank on there, make sure you plumb it in properly though, many people opt to plug the pipe on the inlet mani but this is actually wrong |
chris with a pug
Seasoned Pro Location: Southampton Registered: 16 Feb 2003 Posts: 5,366 Status: Offline |
matt306gti wrote: Highly likely.. make sure you plumb it in properly though, many people opt to plug the pipe on the inlet mani but this is actually wrong Explain please |
eddy_gti6
fit an oil catck tank from the pipe that comes from the Rocker cover to the throttle bodie________________________________________ Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url & = |
mark-house
Nice one Cheers Chaps________________________________________ Peugeot 306 GTi 6BMW 320 td compact M-sport 1967 Mini Cooper 1990 Jaguar XJR 4.0 |
chris with a pug wrote: matt306gti wrote: Highly likely.. make sure you plumb it in properly though, many people opt to plug the pipe on the inlet mani but this is actually wrong Explain please If you are fitting a catch can you still need the pipe to inlet connected,as it 'sucks' out the gasses etc from crank case Otherwise you are just relying on the 'blow by' pressure passed piston rings to push gasses etc out,which on a NASP engine isn't alot A proper catch can/breather tank set up will be filtered inside,to seperate fluids(oil/condensation) from gasses before it gets sucked into inlet ![]() These are proper catch cans that work: http://www.saikoumichi.com/OCC_explanation.htm ________________________________________ Red GTB1756 powered Fabia VRS daily driver,LBSC Gti6 eater........Mac1 ZR R1 kit car build in progress. |
allesclar
Seasoned Pro Location: Sheffield Registered: 17 May 2009 Posts: 4,254 Status: Offline |
allesclar wrote: Ha ha ![]() How do you put up a clicky on this forum by the way?????? ________________________________________ Red GTB1756 powered Fabia VRS daily driver,LBSC Gti6 eater........Mac1 ZR R1 kit car build in progress. |
you have to manually do the [url= stuff________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
welshpug! wrote: you have to manually do the [url= stuff Ok,ta Mei Means nowt to me I'm afraid.............. ________________________________________ Red GTB1756 powered Fabia VRS daily driver,LBSC Gti6 eater........Mac1 ZR R1 kit car build in progress. |
