displaying posts 26 to 48 of 48
Pages (2): 1 [2]
Author Subject: xu7jp4 rebuild
asim_pug306
Porting the standard head is a more expensive route from what I understand
'01 Astor Grey GTi6
'99 Cherry Rallye
Posted 7th Mar 2010 at 00:31
dragoon
but the best option apparently..
xsi head would be the cheapest option I guess
(or keep the standard 1.8 head with 6-bits and a remap... also lowest gain probably..)
Team Wheelwhore
Team Limited Edition
Astor 306 Francorchamps RIP
Virtual Blue 208 GTi
quote:
I Love this place. So many illiterate deluded fool's acting 'ard . . . and so many literate intelligent people to rip them apart and knock them back down again . . . ahh Cool
Posted 7th Mar 2010 at 00:46
joevts
anybody want a 1.8 head to mess about with? i've got one going spare. make me an offer.
Posted 7th Mar 2010 at 01:37
karazu
anyone have a good ideia how to remap 1.8 ecu?
mine is sagem? I know... trow it away... but what other ecu I will put there? gti6 unlocked?
anyone? thanksss
Posted 8th Sep 2010 at 09:31
asim_pug306
Thread revival. Any update on your progress dragoon
'01 Astor Grey GTi6
'99 Cherry Rallye
Posted 8th Sep 2010 at 16:10
dragoon
@ karazu, the sagem is indeed worthless, i've got a bosch which should be remap-able according to local chiptuners
@asim: can't be arsed to do the rebuild, none local that are willing to do/help with the rebuild and I'm far from skilled enough myself.
Already spent too much on the car, not willing to do so anymore. And I need my car daily! (may reconsider when I can afford a second car again)
Currently has 6 manifold/exhaustsystem and it's going to stay with that, sold all my other parts already Smile
Only remaining plans are the bmc cda, an alloy crank pulley and a remap.
Team Wheelwhore
Posted 8th Sep 2010 at 20:56
karazu
What bosch ecu are we talking abouth?
I was wondering if just trading the minfolds and remap would give me at last 20hp more... (that would be fine for me...)
I will have to find that ECU and buy from UK, in Brazil thats going to make me mad, and crazy and I will never find it.
So.. if anyone can help me!=D
Posted 8th Sep 2010 at 21:30
dragoon
normal 1.8 16v ecu... the one that came with my car lol
(but my spare lump has a sagem ecu sadly)
Team Wheelwhore
Posted 8th Sep 2010 at 23:50
doesnt mtter wht the spre lump hs, its the one in the cr tht mtters.
Doh keydord fil!!
Posted 9th Sep 2010 at 00:02
dragoon
Post #35
lol I know, but if it was a bosch he could buy one of me Razz
and get a new keyboard LOL
Team Wheelwhore
Posted 9th Sep 2010 at 00:46
dragoon
Post #36
- thread revival -
not really planning this anymore, but I was pondering about this today and I'm sure some of you can enlighten me
the xu10j4rs head should be plug and play on the xu7jp4, but the one has a 86mm bore while the latter has a 83mm bore, wouldn't this provide, erm, 'incompatibilities'?
(thinking of this because I came up with the idea of replacing a mates broken xu10j4rs header with a ported xu7jp4 one, since we're having a hard time finding a gti6 engine)
sorry for the noob-question, but I'm sure this is the only place I'll get an acceptable/usable reply
Team Wheelwhore
Posted 4th Feb 2012 at 21:21
dragoon
Post #37
mei? phillip? anyone? :p
Team Wheelwhore
Posted 6th Feb 2012 at 22:11
Post #38
its fiiine Smile
not measured the combustion chambers, but they seal fine.
Posted 6th Feb 2012 at 22:44
dragoon
Post #39
so it's possible to use a xu7jp4 head on a xu10j4rs?
cool, thanks once again
Team Wheelwhore
Posted 7th Feb 2012 at 18:35
mrdeey
Post #40
Just a thought ,if the 1.8 is a strong and reliable lightweight lump , how would it cope with a low boost s/c setup and what sort of power gains ? They are 112bhp as standard I think ?
now new booted , boosted and flying again!
Posted 11th Feb 2012 at 11:37
Post #41
yup, would need extensive port work but valve sizes are fine of course.
Posted 11th Feb 2012 at 13:23
Post #42
should work well, would benefit from different cams and port work, Ash ran a 1600 crank in an mi16 block using a later xu head and a supercharger.
though likely to be a long way removed component wise, the WRC engines in the Xsara and 206 were based on the XU7 with special 85mm liners and an 88mm crank.
Posted 11th Feb 2012 at 13:25
mrdeey
Post #43
does that mean the engine mountings etc were the same then (wrc engines), and would fit straight in ? on the port work , the guru rich-w , does not recomend any on low or high boost on the xu10 lumps , so is the head that poor on the xu7and would still need work for charging ?
what sort of power did ash achieve?
Posted 11th Feb 2012 at 13:50
Post #44
standard xu7 uses same engine mounts yes, WRC variants are likely to be quite different, good luck finding one of those LOL
XU7 inlet ports are quite a lot smaller than the XU10, not sure what power ash achieved as a 1600, but there's a few n-a rally builds in the high 100's quite easily.
Posted 11th Feb 2012 at 14:07
mrdeey
Post #45
interesting so , am i right in thinking xu10 head on xu7 block and boost it ? with a map ,on low boost 220 - 235 bhp ? and all from a much lighter block , any idea what the weight difference is ?
Posted 11th Feb 2012 at 17:42
Post #46
roughly 17 kilos, what sandy posted about them is quite interesting, due to the piston+rod+stroke geometry the piston speeds at a given RPM are quite a bit lower than the 1.9 and 2.0 engines, iirc this engine would see the same piston speed at 8k that the others see at 7.2k.
http://forum.205gtidrivers.com/index.php?showtopic=74214&st=0
Posted 11th Feb 2012 at 18:12
Post #47
The head of the XU7 is good, but has very small ports - that makes it great for careful head re-working as it gives you more room to alter the shape and transition of the ports.
Posted 11th Feb 2012 at 18:25
Post #48
specifically the inlet ports, exhausts are fine apparently Smile
Posted 12th Feb 2012 at 09:58
Pages (2): 1 [2]
