displaying posts 1 to 25 of 48
Author Subject: xu7jp4 rebuild
dragoon
I'm thinking of rebuilding the second 1.8 16v engine I have laying around here... (only 84k miles) Since mine (104k miles) had a shocking 14.1 mpg last tank...
So reading through several topics, and not planning to spend shitloads on it, I came to this:
xu7jp4 ported head (sandy seemed to prefer one of these to a xu10j4rs head)
gti6 exhaust manifold
gti6 inlet with 1.8 injectors
gti6 cams and pulleys
lightened crankshaft pulley and flywheel (but how much should they be lightened ideally?)
Now am I missing out anything essential?
Like do the valves&springs need to get upgraded?
Pistons & crank should be fine I guess?
Maybe I should also get the head skimmed?
And get an uprated head gasket? (or just get a new standard one...)
And also, when mapping it, how high can i put the rev-limit? 7k? It's 6250rpm now..
(yes I could drop a 6-lump in, but then I can surely forget getting through MOT here...)
Team Wheelwhore
Team Limited Edition
Astor 306 Francorchamps RIP
Virtual Blue 208 GTi
quote:
I Love this place. So many illiterate deluded fool's acting 'ard . . . and so many literate intelligent people to rip them apart and knock them back down again . . . ahh Cool
Posted 4th Mar 2010 at 21:52
stock HG and minimum head skim possible Thumbs up
alloy crank pulley
lightened flywheel, not sure how much is safe to lighten the XU7 flywheel, its the same as a Motronic 205 gti flywheel, clutch on its own is lighter than a gti6 one Big grin
valves and springs I'd ask sandy, they may need head mods.
also, your MPG I very much doubt is purely attributed to the engine, I would imagine that the ECU temp sender or lambda are needing replacement.
Posted 4th Mar 2010 at 22:08
dragoon
speaking of the clutch, keep it standard? or get an uprated Sachs clutch kit 'here'
(exedy and luk only have replacements)
Crank pulley same as the 6? (can't find much for the 1.8)
About the mpg, I may need to remark that I have 2 lambdas (both just plugged into the decat) not sure if that could be related...
Where can I find the ecu temp sender?
Team Wheelwhore
Posted 4th Mar 2010 at 23:37
lambda issues with a decat may not help Doh I'd get the ecu codes checked.
ECU temp sender is the same as a gti6, green one on the thermostat housing.
the XU7JP4 uses the same pulley as the gti6 IIRC.
Clutch I think would be fine on them, though I'm not certain at what levels they need uprating.
Posted 4th Mar 2010 at 23:03
c.a.r.
Similar spec to the 1.8 I have in the Cab (previously jcphat's)
The 1.8 runs more power with the standard manifolds, there is no proven gain to be made from adding them, and Asim's 306 ran less than standard at an RR recently with this setup.
Also, the cams from the 6 don't benefit the 1.8 in a great way. They'd be great with a remap, but on standard they have no power (can't rely on the torque the 2.0 would have, since you're 200cc down) and the power really kicks in at 3,300rpm, it's incredibly noticeable (on a motorway in 4th, for example). The 1.8 will only rev to 6k or so, so not actually making full use of that 7,250 redline the cams are used to in a GTi6.
All in all, the 1.8 is the most reliable engine they put in a 306 (no common problems) but they suffer all manner of problems when you start playing with them.
If you're going to do it, put an XU10J4RS in. It really is an all-or-nothing thing, since you'll compromise something by adding GTi6 parts.
Edit- lightened flywheel might also cause you trouble, they can make a GTi6 stall depressing the clutch as the rotating mass is lower, so with a smaller displacement engine I could imagine the problem being exacerbated. Or I could be talking from my arse again.
'99 1.8 XS - Sold
'00 GTi6 - Killed by armco
'01 Cabriolet 1.8 - Sold
'96 Eunos Roadster 1.8 Import
Posted 4th Mar 2010 at 23:20
dragoon
Wink
no steering lock either with a 1.8 LOL
remap is something that will be done anyhow obviously, so I'm not worrying about the cams..
Also I've been digging through the forum for a while, and from what I've read the 6' pieces do give some gain..
(already running the exhaust manifold and it drives better, probably a slight gain in power aswell... the standard 1.8 manifold is crap as you probably have seen Smile )
Team Wheelwhore
Posted 4th Mar 2010 at 23:27
I think this graph of a gti6 head cams and manifolds, and a map to suit, disproves your theory about there being no gains from 10J4RS parts not giving gains.
its 163 bhp and 167 Nm, its over 160Nm from 3700 onwards to peak Big grin
Posted 4th Mar 2010 at 23:35
dragoon
lol and 7750 rpm
Is that from a 1.8 with the mods I listed? Hyper Superman
Team Wheelwhore
hats a 100% stock bottom end, with a gti6 top end complete and a mapped ECU.
a ported xu7jp4 will give very similar if not better results from what I have heard from Sandy Brown as there's so much material to work with.
Posted 4th Mar 2010 at 23:39
jcphat
C.A.R. is right about my former car- the exhaust manifold does make a worthwhile difference but the inlet and cams need a re-map to work usefully. The crank pulley is worth it Rich_w's is a great mod- you save around a kilo and have some of the lightened flywheel effect for little effort. The 1.8 engine is a lot lighter than the iron block 6 unit and Sandy advised me that the 135hp 2.0 litre head gives a very decent flow- it was on my list if I hadn't sold the car. To fix the flow on the 1.8 head is much more expensive and while he has had one done by a wizard called Shillibeer (IIRC) it is not a well documented job. You would be looking for a developer not just a machinist.
Re-mapping of the 1.8 ecu is not well established as far as I know- and unlocked 6 one would be a potential solution.
Have a look at Dixons race car thread to see what a 1.8 can do (220bhp).
C.A.R- Dragoon cant do the 6 transplant EU regs in continental Europe stuff engine swaps!! I have seen posts elsewhere suggesting they may outlaw them here.
Just seen Welshpugs Dyno graphs.Ninja Gosh!!
Who needs a great big boat anchor with a gearbox which stops you going round corners!!
New Forum same high quality intellectual debate!
Team Zimmer™
Posted 4th Mar 2010 at 23:46
dragoon
Mmmm, that combined with a lighter gearbox, engine and car...
Something tells me that that car may be faster than a 6 [/opens can of worms]
-somebody get me a bucket for my drool-
the remap: I've found a company that is able to do the 1.8 xsara ecu's (so same as the 306) IF it's a bosch (not the magnetti or sagem shit) and i've got both a bosch and magnetti laying around so I'll try those first..
(my second option was getting a piggyback)
the head: get a good developer or use an xsi head, got it Wink
Team Wheelwhore
Posted 5th Mar 2010 at 00:00
Thumbs up
ditch those heavy wheels and it'll be faster Wink
Posted 5th Mar 2010 at 00:15
jcphat
Rich_w is more or less giving away the crank pulleys now -less than O/E ones and pure engineering! My first real mod on my old car and an absolute cracker!
Team Zimmer™
Posted 5th Mar 2010 at 00:53
dragoon
stupid idea probably but lightening the cam-pulley's any good?
since I've sourced some gti cams (only 65000km) but still need the pulley's Smile
(no need to use new cams? right... they cost like 640
Team Wheelwhore
Posted 5th Mar 2010 at 01:06
I wouldn't try and lighten the original pulleys, I have seen standard ones break, you will wither need standard gti6 (or two xsi exhaust pulleys IIRC) or aftermarket alloy pulleys.
used cams in good condition will be fine Smile
if youre going for a re-map anyway you could get PeterT to regrind the cams for more power+torque...
Posted 5th Mar 2010 at 01:12
jcphat
6 cam pulleys are essential- I doubt you will get enough weight off them to make any difference. Aftermarket ones are a pricey low gain possibility.
Team Zimmer™
Posted 5th Mar 2010 at 01:17
There may be power/torque to be had messing about with advancing the 6 cams as well. Be very careful though.
Was that dyno graph from Powerstation Mei?
Posted 5th Mar 2010 at 04:48
c.a.r.
How would I go about getting the 1.8 engine mapped up then?
Simple case of buying a Gti6 ecu? What about the sensors the 1.8 doesn't have? (CPS for example?)
And how much would I be looking at for it? I'd be very interested in getting it done at some point to see what it can make.
'99 1.8 XS - Sold
Posted 5th Mar 2010 at 04:54
joevts
yeah now imagine that in a 309 Love
Posted 5th Mar 2010 at 05:13
asim_pug306
+1. I know for a fact that the mods have helped this car breathe better than standard even if the power hasn't actually increased. Really want to know more about how to get a proper map for it now..
'01 Astor Grey GTi6
'99 Cherry Rallye
Posted 5th Mar 2010 at 13:54
not that I know of but it is the same format isn't it LOL
Its Craig28 off 205gtidrivers (craig Niven) he's got OKG too (Jon M 's old Mi16 205 shell)
XU7J4RS thread linky
Posted 5th Mar 2010 at 15:31
asim_pug306
Does the GTi-6 head fit straight onto the xu7jp4 block?
'01 Astor Grey GTi6
'99 Cherry Rallye
Posted 6th Mar 2010 at 04:41
have a guess LOL
Posted 6th Mar 2010 at 04:47
asim_pug306
No?
'01 Astor Grey GTi6
'99 Cherry Rallye
Posted 6th Mar 2010 at 04:48
dragoon
LOL plug&play if I understanded it correctly..
But the xsi head should be a better option?
(unless you get the 1.8 head ported Wink )
Team Wheelwhore
Posted 6th Mar 2010 at 22:29
