Author Subject: central locking
jay82rs
having problems with central locking on my gti 6.. turn the key to lock it and it unlocks itself straight away. i have been removing fuse so can leave it secure in car parks etc at the moment.. i sprayed the mechanisms yesterday with some wd40 just incase one was sticking a wee bit and it worked all night until this morning it has gone back to the way it was.. ive tried more lube and bit cleaning but still not working, could it be a faulty connection, lock etc. what can i test to determin what is causing the problem. any info is gratefullCool
Posted 4th Mar 2010 at 03:06
fordygti
I had the same problem with mine, had to disconnect the wires for the cental locking in the doors in the end just so i could lock my car.
Ive been told it most likely to be the central locking box.
Still aint got mine sorted yet! Big grin
Hope this helps mate.
98 onyx black 306 Rallye
58 black Volvo c30 sport
Posted 4th Mar 2010 at 03:12
jay82rs
thanks mate only prob is my key does not work the boot but this could be the problem that the boot lock is seized. ill have a good look at weekend to see if can sort out if not ill do what you suggested
thanks again mateCool
Posted 4th Mar 2010 at 03:16
ant_kernow
mine locks, then un locks if you use the fob.... but if u put the key in the door and turn it.....IT WORKS
oh the stress....
team umpalumpa.
Posted 4th Mar 2010 at 03:19
jay82rs
oh the stress....
hi mate i aint got fob key just the normal one.. doh!!! thanks anyways mateCool
Posted 4th Mar 2010 at 03:21
fordygti
My boots smoothed so have got my boot on a popper on my rear window washer stalk, so mine wouldnt be that.
If it is the central locking box, there are a few on ebay for about
Posted 4th Mar 2010 at 03:22
jay82rs
Posted 4th Mar 2010 at 03:25
ultimate 6 Banned!
Check both the drivers & passengers door looms deffo broken wires i,ve repaired a few 306,s with the problems you mention.
Cossack grey gti 6
Posted 4th Mar 2010 at 14:24
oecken
+1 on that, mine is the reverse, it locks itself (Not so bad) i dont have a check strap on the drivers side, and it is definatly the door loom, wires have split and cause a short. its intermittent and is mostly normal, just sometimes it has a "French" moment, can take the door loom apart, strip the wires and resolder which will sort it.
but as said not had problems with it....
until last week at the parents house, left the engine running, put the windows up then got out to open the garage, the bas**rd locked itself (but obviously doesnt deadlock) so luckily Mr AA Man with his Wedges and inflatable air pockect took about 30 seconds to get in. LOL but the key fob (first time ive had one, thanks to mech repairs!!) locks/deadlocks/unlocks Big grin
Posted 4th Mar 2010 at 17:54
jay82rs
thanks for info guys will have door cards off this weekend to check wiring..much appreciated
Posted 4th Mar 2010 at 22:31
leddra2k
Grrr mine has started doing the reverse! When I go to unlock it its locks straight away and I cant get in the bloody car lol!
Damn french wiring! Big grin
Posted 14th Mar 2010 at 17:58
