Author Subject: rear brake flexi length?
hi, could anybody tell me the correct length for the flexi pipes on the rear of my phase 3 gti6?
the ones that are on there are roughly 21cm and the new braided ones i have are 35.5cm.
are different length brake flexi pipes fitted from model to model?
are all the beams eg exactly same or do some beams use a longer flexi than others eg?
thanks andy
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 3rd Mar 2010 at 23:09
beams with a load compensator use odd length hoses, P3 beams with EBD have equal length lines, can';t remember how long they are but it says on servicebox Thumbs up
Posted 3rd Mar 2010 at 23:15
the unions on the new ones also pass straight through the holes in the brakets/fittings for the flexi hose.
the old ones fited in then stopped when they rteached the nut part, and they had a groove in them to slide a clip in from the other side qand hold them in place.
Posted 3rd Mar 2010 at 23:24
mr swampy s16
**BAD SELLER**
What make are the new ones?
Posted 3rd Mar 2010 at 23:48
leebus
i bought a set of HEL pipes and the rears were different lengths, its one set for all phase 6 from them.
i had measured the old ones at roughly 22cm before i removed them IIRC
Phase 3 White6
Posted 3rd Mar 2010 at 23:55
theyre from miles, he said he will replace them no problem, but as i may be geting a recon beam i dont want to swap them only to find that theyre different again.
my old ones are probably nearer to 22cm than 21cm.
Posted 4th Mar 2010 at 00:04
mr swampy s16
**BAD SELLER**
yes the sets i supply have one hose thats longer than the other but only by a small amount.
Posted 4th Mar 2010 at 00:05
does other peeps graided pipes go through the hole that holds them in place on the beam/brackets??
mine goes straight through as it has a 14mm spanner end on and the originals have a 17mm spanner end so it stops them passing straight through.
Posted 4th Mar 2010 at 00:06
how much difference is in them?
mr swampy s16
**BAD SELLER**
sounds like he has got his kits mixed up as the length and fittings sound wrong
Posted 4th Mar 2010 at 00:07
mr swampy s16
**BAD SELLER**
Its 30mm differance
Posted 4th Mar 2010 at 00:08
what should the fittings be like?
do they use the original clip/large surclip, to hold them in place?
thanks
what is the 30mm difference for? is it for cars with a load compensator as mine both look pretty muich the same size.
Posted 4th Mar 2010 at 00:09
mr swampy s16
**BAD SELLER**
Yes should fit up to the bracket then be held in place with the clip.
Yes difference in length though slight is enough to ensure they fit with the varying load sensor types.
Posted 4th Mar 2010 at 00:20
thanks mate.
Posted 4th Mar 2010 at 00:24
Hmm got a pic?
Mine fitted perfectly, you'd need ones like I have as my car doesn't have a load compensator like a 306.
I'll see if I have a picture.
Posted 4th Mar 2010 at 01:22
mr swampy s16
**BAD SELLER**
the ones i supply are similair to those ends
though with a groove in for the clip
Posted 4th Mar 2010 at 02:29
dont know if you can you make it out from this:
Posted 4th Mar 2010 at 03:19
How did you get on?
  • Posted 8th Aug 2014 at 22:20
    scotzman
    LOL
    Posted 8th Aug 2014 at 22:24
    Excellent, got the correct lines resent and some new clips, good as new now!
    Posted 9th Aug 2014 at 08:40
