Team Running Engine again!Team Negative Camber!
Now appearing at a Trackday near you!!
| Author | Subject: Locking the flywheel |
jeffers
Forum AdminLocation: Leeds Registered: 14 Dec 2003 Posts: 3,702 Status: Offline |
I know this has probably been covered a few times and i have tried a search but cant find a clear picture, i'm currently just tackling my timing belt now according to the FAQ there is an 8mm hole to pass a pin through the bellhousing casing and flywheel to lock up the flywheel in order that the Crank pulley bolt be undone, i cant find this hole so to speak lol can any one post a pic showing me where abouts it is? ________________________________________ Team Running Engine again!Team Negative Camber! My Budget track engine build thread! Now appearing at a Trackday near you!! |
gnrlee
Forum AdminLocation: Leeds Registered: 20 Aug 2005 Posts: 8,891 Status: Offline |
try PM'ing Stanhe helped me with fitting mine I don't remember ever having to pin the Flywheel tho I know he used a plastic guide through the center? ________________________________________ Proud Member of the ASTOR Owners Club |
FAQ is WRONGGGGGGThe 8mm hole to the flywheel is only used on the XUD engine. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
ryangti6
Seasoned Pro Location: Pontypool Registered: 01 Sep 2006 Posts: 1,839 Status: Offline |
welshpug! wrote: FAQ is WRONGGGGGG The 8mm hole to the flywheel is only used on the XUD engine. Are you sure about that? Both of my gti6 blocks have the hole and the notch out of the rear of the flywheel. ________________________________________ Ryan |
yep, the XUD and XU block is the same casting, so yes the hole will be there but its not to be used for this purpose.even on the XUD you should not use it as a means to lock the crank, only to time it up. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
xu7jp
Newbie Location: nilai,malaysia Registered: 18 Sep 2007 Posts: 5 Status: Offline |
dunno about the 6, on my xu7 I put 5th gear and ask someone to step on the brake pedal to prevent the crank pulley from turning. I got it from the haynes manual. |
joevts
Senior User Location: barnsley Registered: 21 May 2008 Posts: 608 Status: Offline |
xu7jp wrote: dunno about the 6, on my xu7 I put 5th gear and ask someone to step on the brake pedal to prevent the crank pulley from turning. I got it from the haynes manual. i recently got an engine in which the bottom end had let go, following the instructions in the haynes manual i thought how am i supposed to do that when there isn't even a gearbox attached, never mind any brakes? so i shoved a claw hammer through the hole in the side of the block, that stopped the crank from rotating |
pugjim
Seasoned Pro Location: Sheffield Registered: 11 Mar 2007 Posts: 1,380 Status: Offline |
according to autodata the proper flywheel locking tool is C115 on this page http://www.lasertools.co.uk/items/pdf/Products/4291_instructions.pdf |
clicky for Jim________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Use an air-gun on the crank pulley bolt, you won't need to lock off the engine to remove the bolt then. You will though when you want to torque it back up, Draper do a flywheel locking tool, it has teeth that engage with the ring gear (there is a gap in the casting at the front of the gearbox where you can gain access to the ring gear) the tool has a slotted hole that you use one of the gearbox flange bolts to hold it with. There is a picture of me using it in my project thread.________________________________________ R H Davey Welding Supplies. I sell new and used welding equipment in the Hampshire area. I take on welding jobs in the evenings, ally casting repairs are one of my specialities but I can weld pretty much anything. PM me with your requirements.Some of my services: (See my for sale threads) Engine mount/chassis repair Solid Beam Mounts BACK IN PRODUCTION Harness bars |
its identical to the lazer tool Jim linked to above BTW ![]() not sure if you could use that on an engine without removing the starter motor, can't remember if there's any access available at the back of the block. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
welshpug! wrote: its identical to the lazer tool Jim linked to above BTW ![]() not sure if you could use that on an engine without removing the starter motor, can't remember if there's any access available at the back of the block. There is'nt, but there is a handy hole that you can poke a deep socket through and go into the holes in the Rich W lightened flywheel I have, not sure what there is to lock into on a standard cast flywheel though ________________________________________ R H Davey Welding Supplies. I sell new and used welding equipment in the Hampshire area. I take on welding jobs in the evenings, ally casting repairs are one of my specialities but I can weld pretty much anything. PM me with your requirements.Some of my services: (See my for sale threads) Engine mount/chassis repair Solid Beam Mounts BACK IN PRODUCTION Harness bars |
jeffers
Hmmm nothings ever easy is it? So what we're sayig is use an airgun to undo.... but how do i tighten it without straining/ pulling against the belt?? Mind you i'm fitting a Rich w Ally bottom pulley so if i pin that it should be okay to tighten against should it not?? ________________________________________ Team Running Engine again!Team Negative Camber! My Budget track engine build thread! Now appearing at a Trackday near you!! |
put it in gear and have an assistant lean on the brake pedal DO NOT TIGHTEN THE PULLEY WITH THE PIN IN IT!!!! ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
jeffers
welshpug! wrote: put it in gear and have an assistant lean on the brake pedal DO NOT TIGHTEN THE PULLEY WITH THE PIN IN IT!!!! Fair enough! Thanks for the replies! ________________________________________ Team Running Engine again!Team Negative Camber! My Budget track engine build thread! Now appearing at a Trackday near you!! |
welshpug! wrote: put it in gear and have an assistant lean on the brake pedal DO NOT TIGHTEN THE PULLEY WITH THE PIN IN IT!!!! + 1 ________________________________________ R H Davey Welding Supplies. I sell new and used welding equipment in the Hampshire area. I take on welding jobs in the evenings, ally casting repairs are one of my specialities but I can weld pretty much anything. PM me with your requirements.Some of my services: (See my for sale threads) Engine mount/chassis repair Solid Beam Mounts BACK IN PRODUCTION Harness bars |
Seasoned Pro Location: Parts for Sale section Registered: 04 Dec 2007 Posts: 7,442 Status: Offline |
I just changed my crank pulley for a lightweight one. I tried putting it in gear, and standing on the brakes, but it felt well spongey when trying to undo it. I ended up using a mini pribar through the little viewing hole on the gearbox casing. Worked a treat. I just made sure I rested it against the teeth that the starter uses. ________________________________________ Chris1999 China Gti6 Supercharged [Fun car] >>Project Thread<<2000 Bianca 306 Diesel [Work runabout] |
jonnie205
Seasoned Pro Location: Bicester Registered: 10 Apr 2005 Posts: 4,146 Status: Offline |
in gear with foot on brake wont work, you will just be winding up the springs in the clutch and moving engine on its mounts. the torque will be wrong doing it this way. Have a mate lock flywheel through bellhousing, or if you have a trusted air gun just run it up tight with that |
