Author Subject: Gaz Gold Set up help
shakey
Just fitted some Gaz Golds along with Jims solid mounts and Ash's ARB to the track car. When we dropped the car it became clear that it wasn't sitting level, I put a spirit level on the door sill and it was the turn of the bubble out, it's also out by the small amount across which I assume is due to the fronts being at different levels.
The car was lowered by 40mm ish when I got it so that's were the rear end is.
My question is what advise has anyone got for getting the thing nice and level (assuming level is best ?)and set up for track use. Do I need a special tool for adjusting the fronts ?
And finally, how hard should I go on the rebound, anyone got track experience with these.
Thanks, Steve
Posted 3rd Mar 2010 at 02:01
smegal
I just got demon tweeks to set the level on mine, AFAIK 2 post ramps are perfectly level so they can get the height right.
Ex SC-6
Now in a Megane R26
Posted 3rd Mar 2010 at 02:55
how are you sure the ground is 100% level and all the tyres are evenly worn?
Posted 3rd Mar 2010 at 03:00
lukejenks101
OT did you get my pm mate?
PS3 I.D - jenkers101
Live i.d - Lukejenks1201
Posted 3rd Mar 2010 at 03:01
Mine were a little off to start with too mate, level them up for definite though mate. When I got mine they came as standard with 350 Lbs springs on which were way too soft even on a significantly lightened carv and as a result I had terrible knocking noises as the suspension bottomed out. I ended up having to send them back for checking until they realised that they had specced the wrong spring weight, they then sent out some 420 lbs and some 450 lbs springs, the 420s cured the knocking and all has been well ever since. I still have the 450 lbs ones though.
As for settings, I was advised to adjust the damping all the way out (Fully anticlockwise to the softest setting) then wind on five clicks of damping as a start point. They are still there as I blew my engine to shit at the very next trackday so I can't really give you much feedback as to how well any particular setup works.
Posted 3rd Mar 2010 at 03:03
I generally ran about 8 clicks up front, 12 at the rear
Posted 3rd Mar 2010 at 03:04
With regards to leveling, make sure you have the car on flat level ground, then try measuring the height from the top of the tyre or top edge of the wheel rim to the underside of the wheelarch. You wo't need any special tools really for this, just a tape-measure, the 'C'spanner that came with the shocks and a jack is handy (to take some of the weight off the car while you turn the locking collars as it makes it much easier and is less likely to wear out the threads.
Posted 3rd Mar 2010 at 03:08
For the rears I was running a similar ammount of clicks on track with my 21mm bars, but I found that to be too hard for bumpy roads as the back got a bit skippy, so backed them off to about 3 clicks for road and 10 odd for trackdays.
Posted 3rd Mar 2010 at 03:10
shakey
Cheers guys much appreciated, let you know how I get on. Oh and Jim the mounts fit a treat, cheers fella.
Steve
Posted 3rd Mar 2010 at 03:16
Steve
Razz LOL
Posted 3rd Mar 2010 at 03:19
shakey
Oh Welshpug, the tyres are brand new and I laid the slab which is +/- 3mm over 6 metres so pretty level
Posted 3rd Mar 2010 at 03:23
pdd144c
Get it corner weighed, if you fit a link to the rear ARB you can adjust all 4 corners. We charge around
FOR SALE
205 Turbo Technics complete and 306 Rallye Race Build breaking.
Posted 3rd Mar 2010 at 19:00
shakey
The cars going to Demon Tweeks on Saturday for setting up including corner weighing and 4 wheel alignment
Posted 3rd Mar 2010 at 20:51
chas
I would also look at Centre Gravity. I have heard good things about them. He'll even Road test the car before you drive it away to see if you are happy with it.
Ex Owner of 2000 Phase 3 306 GTi 6 China Blue - You shall be missed
1974 Triumph Stag
1989 Peugeot 205 GTi 1.6
2003 Alfa Romeo 147 JTD Lusso
2005 Mondeo Ghia X 3.0 Estate LPG
Posted 7th Mar 2010 at 03:40
