Leeay
| Author | Subject: Body Shaking |
leebok
Newbie Location: Kings Lynn Registered: 23 Apr 2008 Posts: 27 Status: Offline |
Hi all a little help.My car has developed a vicious body shake now ive had all wheels balanced traking checked and i have even looked at the bearings. ( IT seems to shake alot more when the car is warm and in top gear when accelerating.) Any help would be much apreciated as it is ruining my experience with the pug.I've checked the FAQ to see if this has happend to any 1. ________________________________________ Leeay |
leebok
Has no 1 realy got any idea!! ![]() ________________________________________ Leeay |
fletch
Track Head Location: The nearest Shell garage Registered: 12 Jun 2004 Posts: 12,273 Status: Offline |
Could be worn gearbox mount?Does it shake the car while idling? Can you move the engine much with your hands? Cyclones are renowned for being incorrectly balanced due to the lack of centre holes, garages don't balance them correctly. |
leebok
No fella the engine is stirdy but saying that my gearhandle wobbles badly when driving and it moves forward if i accelerate!! do you think this cud be it? where would i find the gearbox mount?Cheers for the response________________________________________ Leeay |
fletch
Sounds like knackered driveshafts to be honest. Shaking gearstick is a common symptom of this.FYI gearbox mount is on the nearside in the engine bay under the battery box. |
leebok
driveshaft would wine tho wouldn't it.How could i check to see if its those bad boys playing up________________________________________ Leeay |
phippsy
Seasoned Pro Location: Taunton Registered: 22 May 2007 Posts: 3,050 Status: Offline |
Bent driveshaft rather than worn/deteriorated. Get the car up on axle stands (both sides!) and take off the wheels, start the engine and watch the little fecker wobble like a mofo... |
leebok wrote: Body Shaking + phippsy wrote: watch the little fecker wobble like a mofo... Makes me and think of you and "Get on you Janners"________________________________________ Black X Reg PIII.VGTi 6 A4212 pt 1 A4212 pt 2 Searching the streets of Bristol for 1.36p/day.Joint Kent Leader |
Guess you've found the root of your problem,Lee? |
phippsy
roland rat wrote: Guess you've found the root of your problem,Lee? yes mate... |
