Front Hub, M20, > VIN 808980
= 196 lb ft
Front Hub, M20, VIN 808980 >
= 181lb ft
Front Hub, M24
= 237lb ft
Thanks PhillipM for the torque settings
| Author | Subject: Front Hub Torque |
iplay
Seasoned Pro Location: Number Wang Registered: 18 May 2006 Posts: 3,272 Status: Offline |
I want to get the correct torque setting. How can I tell which torque is for a phase 3 ... ?Front Hub, M20, > VIN 808980 = 196 lb ft Front Hub, M20, VIN 808980 > = 181lb ft Front Hub, M24 = 237lb ft Thanks PhillipM for the torque settings |
Vin being 32808980? Either before or after 328 Vins are around mid 1999 so your VIN should be after that so. Guess the other difference is dependant on which ones have M24? ________________________________________ Black X Reg PIII.VGTi 6 A4212 pt 1 A4212 pt 2 Searching the streets of Bristol for 1.36p/day.Joint Kent Leader |
f*cking tight, i thought i was trying the wrong way the first time i tried undoing 1 of these.________________________________________ andrew315rawson@live.co.ukMoonstone phase 7 gti6 My Project thread: http://www.306gti6.com/forum/showthread.php?id=119992&page=1 |
iplay
thugpuggin wrote: Vin being 32808980? Either before or after 328 Vins are around mid 1999 so your VIN should be after that so. Guess the other difference is dependant on which ones have M24? My Vin is after 32808980 but I am not sure which of the two torques is needed? |
afaik M20 is found on TU engines and MA boxes without ABS, M24 is on any BE box and MA/TU with ABS.Servicebox says RP 08092 (January 4, 1999) not VIN, either way doesn't matter as they were M24 all the time on a 306 XU shaft. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Should be M24 on yours Neil.________________________________________ - Bespoke rollcages/additions/adjustments. Half cages right up to complete custom spaceframes - MSA/FIA spec, CDS, ROPT, T45, etc - PM meEmail me! Custom-made polybushes available - need an odd size or fitment? - anything from batch work to one-off pieces. |
pugjim
Seasoned Pro Location: Sheffield Registered: 11 Mar 2007 Posts: 1,380 Status: Offline |
according to autodata its 320nm for a phase 3 gti6 M24 |
tvrfan007
Seasoned Pro Location: In the garage Registered: 29 May 2005 Posts: 3,488 Status: Offline |
Holy crap, 320Nm for Phase 3's is that right?That must apply to HDi too as the shaft is the same. They don't seem that tight when you're undoing them! ________________________________________ I'm Si btw![]() Night Blue VW Golf GTD Bianca LBSC Rallye - Track/Road Slag Project Thread Sparkling Silver Mini Cooper D - Super Dooper - (The other half's wheels) |
