displaying posts 26 to 44 of 44
Pages (2): 1 [2]
Author Subject: Anti lag
If you can't afford to replace parts if they go, don't bother with it!
Posted 19th Feb 2010 at 02:00
rich_w
mabgti wrote:
Rich.. so launch control controlled via injector pulse would be a no no too?
You would prolly be safe running nitrous at timed pulse as an anti lag binka..Yes
Launch control is different Mabz, all that does is slightly retard the timing to reduce the torque until the wheel slip is reduced to a defined percentage.
The slip is measured by comparing driven wheel speed to that of an undriven wheel
Smile
Contact Details:
07732 822546
Posted 19th Feb 2010 at 15:38
so launch is a bit useless if you have enough power to spin all 4 wheels LOL
Posted 19th Feb 2010 at 15:43
robertinho
I think you don't need to use an anti-lag,
I saw some videos of your car and it don't seems to need it. Your anti-lag is the GT28RS !! this turbo spools very fast!
Anti-lag is just for big turbos or another especific uses. Turbo's durability is affected using anti-lag.
Posted 19th Feb 2010 at 18:22
Depends if you use some accelerometers too, then the system can tell when all 4 are spinning up faster than the car is accelerating..
Posted 19th Feb 2010 at 20:37
fletch
Track Head
He says he just wants it for the noise!
Posted 19th Feb 2010 at 21:01
binkagti
Yep mainly for the noise, am not runing a big turbo, a gt34 i think from memory. Interesting to see what you can do with the car mind, learning lots of stuff.
TEAM Supercharged Rallye
Posted 19th Feb 2010 at 22:00
mabgti
NV motors
gt34? when i had a look at yours USC it didnt look too big.. hence i thought it was a gt28rs..
what power are you running?
Team Supercharged Gti-6
NV Motorsport
Automotive Performance Tuning
0121 448 7515
ECU Remapping/ DPF removal
www.nvmotorsport.com
Facebook Page
Project S6
Posted 19th Feb 2010 at 22:25
john gordon
could just use the abs sensors and gearbox speed sensors. simples Wink
FORD PUMA: the gay car that will have the 6 in the twisties.
Posted 19th Feb 2010 at 22:40
bobdylan_55
Post #35
doesnt anti lag works by dumping unburnt fuel down the exhaust, when it hits the hot compressor blades it combusts, hence the reason it fubars your turbos every 2 milliseconds.
As said there is another few ways of doing it, in the wrc they have a bypass valve of somesort that puts a fresh airstream into the engine until the turbo is spooled or something...
309 GTi6-T
Posted 19th Feb 2010 at 22:44
mangledmetal
Post #36
anti lag works by firing the coil packs, and/or injectors when the exhaust valve is open to keep the turbo spinning up between gear changes.
Same theory as behind a dump valve so there is no stalling of the compressor wheel.
Drastically reduces turbo life, but if not used every day it should be fine!
AS for your management, i dont knwo if yours covers it, its often a feature of after market management, youll have to speak to the manufacturer.
good luck with it chap, plus it sounds pretty coool!!
Going through the gates of Hell Backwards, in a ball of flames!
I'll, save you a place!!
Posted 19th Feb 2010 at 22:51
Post #37
You retard the timing so the mixture is still burning as it goes out of the exhaust ports, hence the huge increase in exhaust temperatures...
Posted 19th Feb 2010 at 22:52
binkagti
Post #38
Was running around the 350bhp mark until she blew, finally decided to get some proper conrods for her and do things properly this time, i dont expect as much power this time as boost has been turned down, would hope around 330bhp but the all important torque will be around the 380ft/lbs same as last time. Made a few mods with this new engine so she should be all good.
I hope
Posted 19th Feb 2010 at 23:30
Post #39
Which still wouldn't tell a car if all 4 wheels were spinning Razz
Posted 20th Feb 2010 at 00:12
john gordon
Post #40
doh, course not, gearbox speed sensor would be traveling at the same speed as the wheels being read by the sensors....
Darwin award goes to me! Big grin
Posted 20th Feb 2010 at 00:23
Post #41
LOL
Posted 20th Feb 2010 at 00:38
scoty18
Post #42
what about turbo modifications to reduce spool up times?
I've heard of people lightening the "drive" shaft compressor and turbine in the turbo and using fancy bearings etc. to get desired effects (not sure how much difference this will make if any). I think there is also various different compressors and turbines available with different blade/fin angles and designs to give the turbo different characteristics.
As for anti lag try these guys http://www.wallaceperformance.co.uk/ they specialise in evos and scoobys but they wont turn down a challenge. They recently done the engine management system and anti lag set up on a pals evo 8. its running approx 530 bhp and has a fully forged engine. Its got switch able maps and the different maps include the antilag setup to suit.
And believe me the car was fast before but now its astonishing. I think the antilag is set up with a direct feed throttle bodie which is electrically controlled and opens to a certain angle depending on the selected map. Antilag for the win! Except for the cost involved. As the costs are ongoing as service intervals are shortened. (so that's once a week on the evo now Wink ) lol Smile
  • TEAM DIABLO!!
  • Posted 23rd Feb 2010 at 23:03
    willygti
    Post #43
    If you like the noise just turn the ignition off when driving in gear and then turn ignition back on - BANG (ps i accept no liability when the manifold gaskets and exh valves die) LOL
    Team Ducati 748
    2003 Subaru Impreza STi
    Posted 23rd Feb 2010 at 23:10
    Post #44
    yeah, that's to kick the throttle open and give more airflow through the engine to the turbine once the antilag is engaged.
    Posted 24th Feb 2010 at 00:59
    Pages (2): 1 [2]
