Author Subject: Knocking - HELP PLEASE!!
steve_l_gti6
HI guys, I've got a knocking coming from the drivers side..
it occurs when i brake and sometimes when i accelerate and sometimes when i go over bumps, just quite randomly TBH but at low speed nearly every time i brake.
i thought it might have been a drop link so i changed it and the knocking is still there, so obviously its not that. The only reason i thought it might have been the drop link as i have fitted new coilovers, wishbones with group n bushes and new ball joints within the last few months.So dont think it could be any of that so soon.
Any help would be great thanks.
cheers steve
Posted 21st Mar 2010 at 07:16
paul_gti6_uk
Checy your top engine mount. The mounting point can crack and the engine rocking will then make knocking noises in the situations you describe.
China Blue 306GTI-6 Big grin Ph3
Team Now Bikeless Sad
Posted 11th Feb 2010 at 21:27
lotek
front wishbone bolt loose , top engine mount cracked,
strut top mount loose, loose balljoint pinchbolt, loose droplink Yes
Posted 11th Feb 2010 at 21:29
Slacken the wishbone bolts, retorque them and see if it goes away, sometimes as the bushes settle in the bolt torque drops just enough for them to shuffle occasionally.
steve_l_gti6
thanks guys Smile Thought maybe top mount cracked but will try wishbones first. Thumbs up
Posted 11th Feb 2010 at 21:43
fletch
Track Head
Could also be ball joint again. I've had pattern parts fail very quickly before.
Posted 11th Feb 2010 at 21:57
steve_l_gti6
This was due to the top mount mounting point braking up. All sorted now Smile
Posted 21st Mar 2010 at 07:14
neil_gti6
What did u have done to sort it?
Team diablo
Posted 21st Mar 2010 at 16:44
scott.n
Weld a small part in with the captive nut sorted Wink
Posted 23rd Mar 2010 at 20:27
gixxer400 Banned!
hello i got same probs on my car here in demark, when i turn slight to the left it makes a sound so i think do one of u guys have a foto of this problem? there is nothing wrong with the balljoint or any thing. best regards kenneth denmark
Posted 12th Jun 2010 at 20:51
gixxer400 Banned!
Posted 12th Jun 2010 at 20:53
