Author Subject: clutch life?
seeing my clutch is starting to get heavier i decided to look at the clutch history of my carBlink last done at 65182miles and even worse the clutch cable was done at 44355miles :shock
now what do i do? replace cable,bushes,clutch and fit lightened flywheel.....(without the misses knowingNinja )
or fit new cable and bushes and leave clutch and dont fit flywheelDry
Posted 10th Feb 2010 at 01:27
stealthcossie
fit the lot whilst it's all off!!
DaveBig grin
Posted 10th Feb 2010 at 01:33
paul_gti6
I had two in two years, all about how its driven Smile
Posted 10th Feb 2010 at 01:38
monty-69
I have just replaced my clutch, greased bushes, and cable but the clutch is still heavier than id like. I have looked into all kinds of ways of making it lighter. I thought about lengthening the clutch arm or pedal slightly but this will just mean more pedal travel is required. Anyone else find the angle of the clutch pedal movement is uncomfortable and a realy long throw. When the pedal is up it pushes your toes up, with your knee nearly touching the steering column. Press it down and your foot is nearly parralel with your leg, one extreme to another.
I have removed the spring on the side of the pedal and replaced it with a slightly stronger spring which seems to have made the pedal a bit lighter. The pedal is still returning fine and has free play at the top. Im thinking if you could get the spring setup made from steel with polished load surfaces you could put a stronger spring in place. If only i was an engineer.Blink A little warning - My knee is now shagged from the previous heavy clutch that got heavier over time without me knowing. Was fine one day, running, cycling, boxing, then the next day i had knee pain. I used to be able to drive any car or van no probs, now i struggle to drive any car with a cable clutch, can't run, cycle and even limp walking 3 months later. Mellow
Posted 10th Feb 2010 at 01:48
greenbelt
Don't do half a job No
Do the whole lot once. You don't want to go through the hassle of doing it again in a couple of years
Standard Black 6
Black HBSC6 Smoke
Posted 10th Feb 2010 at 01:43
hmmm just what i was thinking so how much am i looking price wise? 200 odd for flywheel, clutch Huh? no idea LOL clutch cables cheap anyway.
Posted 10th Feb 2010 at 01:59
oecken
I havnt noticed any clutch replacement in mine, and sure it has not been done in the last 2 and a bit years, but still has a fair bit of life in it from what i last saw, not looking forward to the bill
Posted 10th Feb 2010 at 02:04
jaydog81
How many miles is a new clutch due roughly.
I pulled out of a road the other day with high revs and releasing the clutch and it smelt quite a bit. Big grin
*jay81.
Phase 2.5/S-99
Team i live for working,Paying bills and funding my hobbies. I wish my life could be just living for a pink "I love the 6 sticker".Laugh my ass off
Posted 10th Feb 2010 at 02:31
oecken
could the smell be due to you not lifting of the clutch quick enough before the loud pedal was flat Shut up
Posted 10th Feb 2010 at 02:38
jaydog81
I rode the clutch slightly as the pedal has a jumpy action due to the cable being old.
*jay81.
Phase 2.5/S-99
Posted 10th Feb 2010 at 02:54
My original one lasted 110k or thereabouts and the bearing went rather than the clutch plate.
You need to grease the nylon bushes for the arm as well as get a new cable.
Posted 10th Feb 2010 at 04:33
miles
Mine did 240k and it still had life left in it, Only changed it as it was out
www.pugracing.com
Posted 10th Feb 2010 at 04:51
ok then im just gunna change the cable and grease the bushes and see how it is
Posted 10th Feb 2010 at 05:26
greenbelt
Doh
You might regret that decision in a few months... then again you might not.
Good luck with it anyway Thumbs up
Standard Black 6
Black HBSC6 Smoke
Posted 10th Feb 2010 at 17:50
anderoo
The bushes are cheap and easy to replace if doing the clutch so I'd do that as well as greasing them.
Pics of my 6
My 6 on Google Video thanks to coxy306Xsi
Posted 10th Feb 2010 at 18:04
iplay
My last valeo clutch lasted 10k miles ... clutch plate was like new but the springs were mashed up. i will get some photos up shortly. A Sach's clutch is the new valeo imho Whistle
Posted 18th Feb 2010 at 00:10
