Author Subject: TVR Brake Judder
gti6girl
I had steering wheel judder with the standard brakes and wheels. I then changed the wheels for brand new compo's which helped a little. I then upgraded to Carl's TVR brakes and the problem went away.
A few hundred miles later the problem has come back. It only seems to do it when braking lightly but the judder is quite excessive. Under hard braking it seems to be fine
i cant really see how you would warp a disc that is so fat
any ideas?
Posted 2nd Feb 2010 at 20:50
Given the hubs a damn good clean with a wire brush?
Posted 2nd Feb 2010 at 20:59
gti6girl
i did untill they were like chrome Smile
Posted 2nd Feb 2010 at 21:00
Get a dial guage on them and check for runout.
Posted 2nd Feb 2010 at 21:03
check the hub nut is tight and there's no play in the bearing Smile
Posted 2nd Feb 2010 at 21:12
stu
I had a similar thing when I upgraded to Ash's 330mm kit.
After changing my Wishbone bushes for Rich_W's Roller Bearing ones the problem disappeared.
I know Stan_306gti6 had the same problem, he also changed the bushes and the problem also disappeared.
Posted 2nd Feb 2010 at 21:18
birk
I had this problem on gentle braking when my wishbone bush had snapped in half.
Dimma + Gt35 turbo = Ninja
Solid rear beam mounts £130
07889376885
Dan
Posted 2nd Feb 2010 at 21:19
gti6girl
i also changed the p bushes and ball joints?
Posted 2nd Feb 2010 at 21:20
birk
Maybe the bolts have come lose on the p bush and the bush is wobbling around when braking, worth a check.
07889376885
Dan
Posted 2nd Feb 2010 at 21:24
stu
Did you replace the bushes with standard ones?
I did this and the problem was still there, swapped them for Rich_W's solid ones and I've not had a problem since.
Posted 2nd Feb 2010 at 21:46
gti6girl
Yeah I put pug ones back on
I wonder if it would work if I put pug sport group N bushes on?
Posted 2nd Feb 2010 at 23:57
fletch
Track Head
Just get a set of bushes from Rich, they last forever and really firm up the handling and get rid of the slack.
Posted 3rd Feb 2010 at 02:14
stilly
got the ones that rich-w sells nick... the problem will go once you have them fitted mate, believe...Big grin...as you would say...
deaf in 1 eye blind in 1 ear Crazy......
307 136bhp daily drive.....
306 rallye stripped out and charged.....
lee_gti6 also known as "the tit".....
stan_306gti6 also known as "stan the dick".......
Posted 3rd Feb 2010 at 11:18
tvrfan007
What are they like for fit-and-forget though? Don't they need regular greasing?
I'm Si btw Tee hee
Night Blue VW Golf GTD
Posted 3rd Feb 2010 at 12:40
fletch
Track Head
Not really, just do it when you do a service, no big deal.
Posted 3rd Feb 2010 at 14:34
only takes 2 minute at the most to regrease the p bush though, as theres grease nipples on them.
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 3rd Feb 2010 at 14:48
^As above, not that hard to have a quick whip around with the grease gun when your giving the car a check over.
Posted 3rd Feb 2010 at 17:56
tvrfan007
I probably do about triple your weekly mileage though. Laugh
Anyway, I digress. Thanks. Smile
I'm Si btw Tee hee
Posted 3rd Feb 2010 at 23:31
Yeah, well I don't have 'em, so Razz
Posted 3rd Feb 2010 at 23:36
ive got some with a 45 degree angle grease nipple on them, there well easy to get a grease gun on.
thanks dave by the way mate for them.
Posted 4th Feb 2010 at 00:40
bininoz
I had exactly the same problem. I bed the pads in but had not bed the rotors in first, so I had warped the rotors. Got them skimmed and then I ran the rotors in with only light breaking for 150 miles. They have been spot on since.
Team High Boost Supercharged Gti-6™
Posted 4th Feb 2010 at 19:06
gti6girl
This is paula's car so i don't think they are warped
Posted 4th Feb 2010 at 21:26
davedgti6
no probs mate
Posted 5th Feb 2010 at 03:10
