Author Subject: throttle cable pic
jord294
hi guys
has anyone got a pic of the route of the longer type throttle cable for the gti6, which is supposed to run over the rad please?
especially pics of any points at where the cable should be fastened. as i have a metal 'L' shaped bracket on my cable, but for the life of me, i have no idea where it might go
cheers Thumbs up
Posted 1st Feb 2010 at 18:01
cosmic spanner
Moral objector
My ph2 used to have that setup clipped to the top of the rad, but I can't find any decent pics sorry Sad
As you're looking at the engine bay, the cable goes down the left hand side of the engine mount/cradle (ISTR it attaches to the engine mount area maybe that's what the bracket you have is for) then curls round runs along the top of the rad (clipped in by P clips to the lip of the top edge of the rad) then round towards the battery box, then round on itself again before it gets to the throttle body. Some tight bends in it and therefore places where it could stick/snag..
So most people (and ISTR the path on later cars) is to go in an S - curve round by the PAS pump/bottle area, over the cam cover and back round again to the throttle body. Like this:
If this helps at all!
Democracy is two wolves and a lamb voting on what to have for lunch..
..Liberty is a well-armed lamb contesting the vote.
Project é - my 306 project thread.
Posted 1st Feb 2010 at 20:06
jord294
thanks for that.
but could do with a better pic
i have the bracket which mounts to the engine mount, but i have an 'L' shaped bracket which is on the throttle cable and looks like it should fasten to by the battery box Confused
the cable has a rubber sleeve almost on the straight before it goes to tb. how is it held on the bracket which is bolted to the head ?
even looked on service box, but no luck
cheers
Posted 1st Feb 2010 at 21:17
cosmic spanner
Moral objector
Not sure if it clips to the battery box, or just curves around there, from memory most of the clips were plastic and either tie it to other pipes or cables. I don't remember an L shaped bracket. Unsure
Not sure what you mean.. I've nicked some pics from various FAQs (none on the throttle cable, but of nearby areas) -
Posted 1st Feb 2010 at 21:46
fletch
Track Head
I think he is talking about the plastic bracket in the first picture you posted. If you follow the cable back from the TB upward, you can see the bracket attached to the head. This is a simple plastic clip that goes round the cable.
jord294
just a clip Happy
cheers.
Posted 1st Feb 2010 at 21:53
You will see a tab on the side of the battery box with a hole which is where you bolt the cable to.
What make of cable did you get?
Posted 2nd Feb 2010 at 01:00
jord294
have you got a pic please ?
it's the original phase 2 cable
Posted 2nd Feb 2010 at 01:17
You may be able to see it here:
Posted 2nd Feb 2010 at 04:57
jord294
Thumbs up
perfect mate. thanks very much
just need to get hold of a battery cover now
Posted 2nd Feb 2010 at 09:48
