Author Subject: Replacing Power Steering Pipe
silky
When replacing the whole pipe, from pump to ram, how do you get the pipe at the pump end undone ?
It is a solid pipe, but if I try to undo the nut then the pipe twists with it....any ideas ?
Posted 1st Feb 2010 at 17:41
You need to hold the bit next to the nut (pump side) with some mole grips, then use a spanner to undo the nut.
I did it yesterday, had to get a mate to use the mole grips while I undid the nut, was a bit tight.
HTH Thumbs up
Posted 1st Feb 2010 at 17:45
silky
What I could see was the pipe heading towards the pump, then a nut, then the thread and then a larger nut on the pump itself.
I tried undoing the nut next to the pipe first but this didn't work, also tried holding the bottom bolt while undoing the top one and still the pipe twisted
Posted 1st Feb 2010 at 17:47
silky
Do you mean the threaded part ?
Posted 1st Feb 2010 at 17:48
fozzy_255
I had trouble with my PAS pipe, it turned fine on the thred but then got jammed with dirt so wouldt turn on the pipe if that makes sense but it was turning in the actual pump.
As i was replacing the pipe as it was leaking i snaped the pipe off above the thread and then just undid it by hand.
Im not sure if that makes sense.
Posted 1st Feb 2010 at 17:55
Would you be able to get a picture of the bit you mean?
Posted 1st Feb 2010 at 17:56
silky
If the pipe is coming off then is it ok to snap it off and then not worry about it twisting ?
Will I then be able to undo the nut etc to be able to put a new pipe on ?
Posted 1st Feb 2010 at 17:57
fozzy_255
the pipe has a nut/thread thats part of the pipe which threads on the pipe and into the pump, if you have the new pipe to replace it with you can have a look.
Don't snap it unless you are sure you have the parts to replace it. the pump should be left with just a threaded whole.
It was my Dturbo which i replaced pipe on but i can't see there being any difference. Try and get some photos.
Posted 1st Feb 2010 at 18:42
fozzy_255
Ok bare with me im not good at explaing.
This is an image i can find thats closest to what i can explain. This has a thread on the inside aswell as the outside. Its part of the pipe not the pump. so if its loose in the pump and not on the pipe.
What i did was snap the pipe and just undo it by hand as was seized on the pipe but loose in the pump.
Does that make sense. Im not one for good description, im more of a being there and showing.
Posted 1st Feb 2010 at 18:49
silky
So I could snap the pipe off just above the nut, then undo this part from the pump ?
Posted 1st Feb 2010 at 18:54
silky
The large metal clamps/clips which join some of the rubber parts of the hose to metal parts, can these be undone and done up again easily enough ?
They are pretty big, is it a special tool that you need
Posted 1st Feb 2010 at 20:17
silky
may be called a high pressure crimped joint
Posted 1st Feb 2010 at 20:22
fozzy_255
I cnat say for saure without seeing wat you doin but if the pipe is knackered anyway and being replaced nothing lost by snapping it. And as for the high pressure crimp joints, ide replace the whole pipe as one unit metal and rubber bits. As you dont wnat to have further leaks in the futre.
Posted 1st Feb 2010 at 21:57
silky
I'll try and get some pics tonight, though is very dark so camera flash will have to do.
Might try and heat the nuts up on the pupmp to help un-seize them
Posted 1st Feb 2010 at 21:58
the ends that screw into the rack are exactly like a brake pipe union, and similarly they often seize onto the pipe giving the issue you are experiencing now.
heat wont help I'm afraid, it may also damage the seals so I would avoid trying that.
if you are replacing the pipe I would just cut them off as mentioned, and use a 6 sided socket on the union.
Posted 1st Feb 2010 at 22:05
silky
Got the end off that goes into the rack, its the end that goes into the top of the pump that is seized and twisting the pipe
Posted 1st Feb 2010 at 22:07
jonnie205
do as welshpug says, that sounds the best solution
Posted 1st Feb 2010 at 22:28
