Author Subject: Squeaky Noise
khong
Hi all. I am new to this forum and this is my first post.
Amazed by the superb handling of the 306 back in uni days I bought a used 1998 model GTI 6 in May last year. All has gone well except minor issues such as fuel leak and transmission fluid leak from the lower pipe out of the transmission fluid reservoir. However, there is one issue that remains. My car's driver side front end makes this loud squeaky
1998 GTI-6 All stock
Posted 20th Jan 2010 at 08:30
Are you sure its the front end as it could well be the beam? Could be a knackared damper I guess that lubricates itself aftrer going over the humps.
Also a small point but there isn't a transmission fluid pipe or reservoir on these cars. Probably power steering leak Smile
Welcome to the forum by the way Thumbs up
Posted 22nd Jan 2010 at 02:21
khong
Thank you for your reply. Could I have the technical name of this 'beam' you referred to (if any) so that i can tell this to the machanic on my next visit. Yes i mean the power steering reservoir. Got too carried away cos tranmission fluid goes in there.
Thanks.
Posted 22nd Jan 2010 at 07:30
khong
Also to add. I am almost certain that the noise is from the front driver side if that adds to anything.
Posted 22nd Jan 2010 at 07:47
The rear beam is the suspension crossmember under the boot of the car that the trailing arms attach to.
khong
Hi all, I've posted a video to capture (http://www.youtube.com/watch?v=3A9yv2Mcr8w) the noise as it happens. As you can see and hear, the car went over the speed hump in less than 10Km/h and occurs when the front wheel is pushed upward by the speed hump. It immediately goes away afterward. I hope this will better describe the situation. Any suggestion on what is causing this noise is much welcomed. Thank you.
Posted 26th Jan 2010 at 21:52
Has your front damper got any signs of an oil leak?
It sounds very much like a damper that's short on oil from that, I'd double check the front wishbone bush is torqued right up too though.
Posted 26th Jan 2010 at 21:58
