Author Subject: will my standard pads last a day on track?
gti-dan
just had new pads done at garage. mintex pads but nothing special. will the last a day on track? i dont want to pay and get there and they melt after a few laps!
is it possible to swap pads (and then swap back etc)????
Posted 13th Jan 2010 at 01:21
allesclar
should be fine, but vastly depends on how hard you drive.
Team allesclar ®
Posted 13th Jan 2010 at 01:24
smighall
Smeg-all
I'd personally say no, but i'm very hard on the brakes on track. I'd get another set of decent pads and just use them on track, change them over in the morning, and swap back to std pads if you're concerned.
Meh
Posted 13th Jan 2010 at 01:28
gti-dan
ok i think i might do this. i might just do a half day trackday and see how the pads hold up.
Posted 13th Jan 2010 at 01:36
lotek
my pads were fine at snetterton..
not sure how they would fair at different tracks, but they took a beating on my outing.
Posted 13th Jan 2010 at 05:02
SteviePut
I'm with Sean, I seem to be hard on my brakes be it on track or the road. I personally would cook standard pads within 2 or three corners!
Incidentally, the brakes in the company van are only lasting 15k at most before metal starts hitting metal. Crazy really when you consider it has a 20k service interval. I may be hard on my brake but the point I was trying to make to Citroen garage was that it's not as if I carry much weight in the back. If I did I suspect I'd be back every 10k for new pads/discs.
Having said all the above, the brakes in the van WILL not fade - no matter how hard I try. Most likely because you can't get it to go fast enough before having to brake again Laugh my ass off
Posted 13th Jan 2010 at 12:49
My Brembos (Bigger than a standard disk, and better cooling due to them bieng ally calipers) overheated standard pads in 3 laps at Castle Coomb. If you are doing trackdays, invest in some decent pads so that brake fade does'nt spoil your day.
Posted 13th Jan 2010 at 14:49
gti-dan
OK - I WAS GOING TO GET FERODO DS2500'S BUT COULDNT AFFORD THE EXTRA COST AT THE TIME. NOW IM THINKING THAT I'LL GET THEM AND FIT THEM. THEN IF POSSIBLE - GOING BACK TO MY ORIGINAL QUESTION - I WILL REFIT THE OEM'S AFTER THE TRACKDAY. IF THAT IS SAFE AND OK TO DO SO.
CHEERS
Posted 13th Jan 2010 at 17:25
lotek
fit the ferodos, and take the oems with you just in case.
but depending on your driving style you may well find that the pads are fine after you have finished your trackday.
Posted 13th Jan 2010 at 18:11
jeffers Forum Admin
Fit ferodos, and if it makes you feel better either keep your oe ones as spares or swap them before and after your trackday, i personally only use my car on the road for travelling to and from trackdays and its running ferodos all the time and have no probs.Wink
*Edit* I personally would not run on standard pads on track having experienced before how badly they can go off if your anywhere near hard on the brakes! Just my 2p worth! Thumbs up
Team Running Engine again!
Team Negative Camber!
Posted 13th Jan 2010 at 21:50
darkgti6
and when standard pads go boy do they go, ive gone from driver to passenger in my car approaching a roundabout beforeCrazy
Team Peugeot Sport 308 Gti�
Posted 14th Jan 2010 at 05:03
nealh
I did a full day at Oulton (with Jeffers actually) on standard discs and pads, and they were absolutely fine.
I tend to be very easy on my brakes on the road (silky-smooth style, probably LOL) and take it pretty steady on track - regular breaks (15-20 minute sessions, 20-30 minute gaps between them) to allow the car to recover, and had no fade.
I will be doing Sunday at Mallory on the same discs and pads, and I'm expecting them to be okay too. Fingers crossed Smile
E39 M5
Ph2.5 GTI-6
Posted 22nd Jan 2010 at 22:31
