Author Subject: Wishbone bushes on lowered car
davenegus
Hi there
Im getting new wishbones and ball joints fitted on tuesday and i swear i read somewhere on here about adjusting the angle of one of the bushes to allow for a lowered car.
My car is lowered either 30-40mm all round and just wondered if i need to tell the garage to allow for this ?!
Posted 9th Jan 2010 at 19:31
tez_306
Basically you rotate the angle at which the bush sits neutrally (with no load acting upon it).
When you lower a car, the control arm angles upwards and therefore the bush rotates - the aim is to rotate the bush slightly so that it is sitting in the neutral position when the vehicle is on flat ground.
Posted 9th Jan 2010 at 21:23
davenegus
and is that especially important if yoy have a lowered car ?
Posted 10th Jan 2010 at 01:49
if you want the to last yes Smile
Posted 10th Jan 2010 at 02:28
jeffers Forum Admin
Basically, do not tighten up the front bush bolt til the car is on the ground, ie the bush is sitting in its natural position.
Team Running Engine again!
Team Negative Camber!
Posted 11th Jan 2010 at 01:18
