Author Subject: can i fill gear oil from top, instead of taking wheel off
denwar
can i fill up my box from the top instead of the side, i hate doing it that way,pain in the tits, and its baltic, am i correct in thinking that there is a white plastic plug on the top of the box somewhere, any info or pics appreciated.
denwar
Posted 9th Jan 2010 at 16:48
lotek
Laugh my ass off
your not suppoesed to fill from the side. lol
that hole is a level indicator haha
on top of the gear box there is a black plastic nut. undo it and fill it frm there. use the pug stuff. its cheap and will help with gear changes Thumbs up
Posted 9th Jan 2010 at 16:53
SteviePut
lotek wrote:
Laugh my ass off
I believe you are supposed to fill from the side until it floods out. The top it meant to be a breatherSmile
Posted 9th Jan 2010 at 18:09
lotek
fill from top. with side bolt undone, keep filling untill it runs out of hole Yes
Posted 9th Jan 2010 at 18:13
24seven
BE3 boxes are filled from the side until it begins to run out else you could end up overfilling. The top I believe can be used as a level indicator using the dipstick.
Posted 9th Jan 2010 at 18:42
lotek
well i stand corrected.
ive always done it trough top
Posted 9th Jan 2010 at 21:23
ian7675
Techno Viking
I always filled mine from the top too even though I know you're supposed to fill it from the side. Surely it can't matter too much?
Less than 24 hours to go!
Posted 9th Jan 2010 at 22:04
farmer
I fill mine from the top, and make sure I put the correct amount of oil in. (2.3L) No problems here!
Long live the Sigma 6 Big grin
Team Phase 1 supercharged
XBL ID: farmer uk1
Posted 9th Jan 2010 at 23:26
bobdylan_55
haynes manual says to fill it from top until it leaks out the side hole...
on another note, i know somebody who filled their engine oil up by pouring down the dipstick LOL
309 GTi6-T
Posted 9th Jan 2010 at 23:28
good luck getting a dipstick down the breather hole Laugh my ass off
I always take the level plug off with the wheels on full lock left, and just fill through the breather, plastic tub on the ground under the level plug.
Job jobbed :thumbhsup
Posted 10th Jan 2010 at 02:34
Do phase 1's have a 0.15 litre additional capacity? Phase 2 and 3's say 2.15 litres. I know oil amount is different in engine for air con models.
I reinsert mine up through the sump plug if this helps and when it pops out of the washer jets I know it's full so shut the sump plug.
Posted 10th Jan 2010 at 03:54
