Author Subject: rear demist not working
306xsaiii
Hi can anyone help on the above??? I got a new switch off e bay but not convinced thats the problem.I hear the relay click but nothing else happens oh yeah its a ph3Sad
Posted 6th Jan 2010 at 19:52
Rich E Forum Admin
Faulty relay (unlikely if it clicks but check it anyway), faulty wiring or broken elements on the screen.
Check for voltage at the screen terminals and work backwards from there.
Posted 6th Jan 2010 at 20:03
306xsaiii
Cheers il do just that!!
Posted 6th Jan 2010 at 20:04
Rich E Forum Admin
Oh, I forgot to ask - do the mirrors demist? They are on the same circuit.
Posted 6th Jan 2010 at 20:07
306xsaiii
Am not sure , someone else mentioned that the mirrors demist
Posted 6th Jan 2010 at 20:12
They will only demist if the mirror glass is the correct type. If they've been replaced at any point with the wrong type then this feature will not work. Unlikely but something to consider if there is a fault with demist too.
Posted 6th Jan 2010 at 20:17
ant_kernow
i know it sounds silly....but have you checked its plugged in around the rear inside of the windonw....?
team umpalumpa.
Posted 6th Jan 2010 at 20:40
306xsaiii
No mate good answer but i did check first cheers!!
Posted 6th Jan 2010 at 20:50
streetbadger
theres a connector under the dash pass side by heater motor, think its red, pull it apart and check if its burnt out on one of the wires, cant remember wire number off hand, but it was quite a common fault. if it is burnt cut the wire either side of the connector and bridge around it, thats easier than trying to replace or repair the connector.
Posted 7th Jan 2010 at 00:56
SteviePut
Fuse? The relay will likely still click with the fuse goneWink
Posted 7th Jan 2010 at 02:17
misschief
Mine hasn't worked since I got it! Will check for the red connector. mine still clicks and it seems if I hold it in the light does come on although it's not very bright. It doesn't stay on though when i let go of the button.
Posted 7th Jan 2010 at 04:13
rallyestyle
Same as mine, dindt bother me until the recent ice Doh
I had assumed it was probably the fuse so was going to check it at the weekend Yes
Just Drive It
Posted 7th Jan 2010 at 15:36
waday
mine dont work too tried everythin to get it working , guess ill make do with out LOL
Hyper GTI-6 diablo & astra hair dressers mobile Smile
Posted 12th Jan 2010 at 02:33
lilnickgti6
My rear de-mister doesnt work either, there are two conections either side of the window at the top, one has snapped of on mine.. does anyone know how much it would cost to fix???
Posted 19th Jan 2010 at 23:44
Could you epoxy it back on then connect using silver paint?
Posted 20th Jan 2010 at 01:08
lilnickgti6
seems to have snapped at the two silver joints on the window, but i think part of the connector is missing also, is there a way i can bodge the coonnection?
Posted 20th Jan 2010 at 01:18
