displaying posts 1 to 25 of 34
Author Subject: Tapper?! updated/ better vid added
will130787
How can I tell if my engine is a tapper rather than just the injectors etc? Is it loud or do you need the bonnet up with your head in there to hear it? Sorry if it's a dumbass question!
Ex Astor 6 owner Sad
Also an Ex owner of a Bianca 6 Sad
Now an ex owner of a 2005 9-3 2.0T 210bhp Aero Swedish Saloon thing!! Soon to be 250bhp.... Superman
Now driving Mk5 Golf GTTdi, mile muncher
But still live for the 306 Ninja
Posted 28th Jan 2010 at 17:43
lwgti-6
If the tapping increases with the increase of engine rpm then it will more than likely be a tapper. Injectors tick ever so slightly. Better of getting a vid mate..
EX Bianca 6 owner,
Now drives: Octavia vRS
Posted 28th Dec 2009 at 18:59
toby
TBH the best thing to do is buy or borrow a compression tester, screw it in place of each spark plug (remove the other leads so it doesn't start)then crank it over for a few seconds, you should have readings from each of the four cylinders all pretty much the same with a reading around 170. If you have even a slightly bent valve this would give a very different reading.
Otherwise put a screwdriver to your ear and move it along the rocker cover whilst its running, if there is a bent valve you will get a harsh tapping noise roughly in the area of the bent valve.
Previous Peugeot - 2000(w)GTI-6, Me old China, Supercharged with working aircon!
Posted 28th Dec 2009 at 20:25
darkgti6
Also before performing the compression test pull the plug out of the fuel pump under a flap of carpet under the drivers side rear passenger seat. Dont need any fuel to perform a compression test Thumbs up
Team Peugeot Sport 308 Gti�
Posted 28th Dec 2009 at 21:44
will130787
Cheers fellas, a mate has a compression tester so will do this when I have a mo......
Posted 28th Dec 2009 at 21:47
webster
A novice way of checking injectors is screwdriver on them and pop other end to your ear :p
cress87 wrote:
I'm stopped for speeding on a daily basis but now the police are aware that I live for the 306 they dare not interfere, just sit in their cars quaking as I drive past.
Posted 31st Dec 2009 at 17:05
will130787
Thread revival! Finally done my compression check, these are the results from left to right cylinders: 180-192-183-195
do they sound good??
Posted 23rd Jan 2010 at 22:16
Not as good as they should be IMO, get a video up of your engine ticking over, we will soon tell you if you have a bent valve or not. Yes
Stan.
Posted 24th Jan 2010 at 18:39
will130787
Ok will do that in the morning! She hasn't lost any power or pull that I can tell, what ideally should they be? Toby said it should read around 170, there all above....
Posted 24th Jan 2010 at 19:33
Ideally, anywhere between 195-220psi is a good healthy '6' engine. Yes
Stan.
Posted 24th Jan 2010 at 19:42
will130787
Even so, they aren't miles apart from eachother so that suggests that I haven't got 1 poor cylinder?!
Posted 24th Jan 2010 at 19:50
joevts
that's what i would have thought, unless you have a bent valve in each cylinder LOL
Posted 27th Jan 2010 at 00:23
Depends if you had the throttle open as well. I guess the tapping hasn't gone after doing the plugs up again then? What oil is it running on?
Posted 27th Jan 2010 at 00:38
will130787
No I didnt have the throttle open, just turning over the engine! The noise has definately improved, think it could just do with a flush out with an oil change tbh. Its Castrol Magnatec Fully Synthetic 5w40 iirc
Posted 27th Jan 2010 at 19:44
ryangti6
As Stan said get a video up, unless you actually have someone who knows what they are listening for you wont really know without inspecting the head.
The problem with doing a compression test is that in some cases the valve will still be sealing okay but just making a tap as it does so hence they usually run fine as tappers.
Ryan
Posted 27th Jan 2010 at 20:05
will130787
It was my usual mechanic that looked at it, he's a spot on fella so I trust his judgement tbh. Will still do a vid and see what you guys think
Posted 27th Jan 2010 at 20:46
170??? more like 210-220 isnt it??
i did a test without opening the tyhrottle wide and it buggered my results up.
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 27th Jan 2010 at 21:00
will130787
I did it exactly what toby said, just cranked it over! No throttle involved at all with all coil pack leads disconnected so it didnt fire!
Posted 27th Jan 2010 at 21:06
will130787
I think i had my phone too close to the engine! Will do another tomo (sorry about it being dark)
Posted 28th Jan 2010 at 00:07
kit
My speakers aren't the greatest, but I can barely hear the tapping. Yes it increases slightly towards the end with the revs, but it sounds like the injectors to me.
If it was a bent valve it would be much louder?
Racing driver, fighter pilot, astronaut, compulsive liar.
Posted 28th Jan 2010 at 00:14
cooper666
sounds to me like big end bearings might just be on there way out
seems to have a knocking more than tapping might be my crap laptop though
clio r27
ps3 id:cooperkloe
Posted 28th Jan 2010 at 00:23
will130787
Might be your laptop mixed with me filming it on an iPhone 1 inch away from the engine! Haha
Posted 28th Jan 2010 at 00:50
cooper666
LOL LOL
clio r27
ps3 id:cooperkloe
Posted 28th Jan 2010 at 00:53
will130787
It is more of a knock than a tap! Just not massively sure what it was and immidiately got paranoid about tapping!
Posted 28th Jan 2010 at 01:03
24seven
If it was a big end knock you'd feel it through your feet while driving, and it would be a lot louder than that.
That just sounds like a slightly noisey lifter to me, nothing untoward really. If you want to pinpoint which one it is try using a screwdriver as a stethoscope. get a long screwdriver, put the tip on the rocker cover roughly where each valve/cam lobe might be and press the handle hard into your ear closing the flap just in front of your hole (ooh err). You'll know what you're hearing when you hear it, trust me.
Do this on top of the injectors as well if you want to listen to them. That doesn't sound like an injector ticking to me as it's a little slow, but then I'm not sure if the '6 uses batch injection fire or sequential.
Posted 28th Jan 2010 at 17:13
