Author Subject: hid kit flickering
skinnyman76
got a cheap plug n play hid kit both lights flickering slightly checked all my connections are tight and correct, still flicker!! any ideas? cheers
pug power !!!
i got the need for a 6 speed!!!
Posted 27th Dec 2009 at 00:50
jose
it could mean they are not getting enough power and flicker on and off, or not a good earth?
Nile Blue GTi6
Alpine White 205 GTi 1.9 - Project
Air Con Pipes Thread.......
Machine Polishing - Paint Correction - Swirl Removal in West London - PM for details
Posted 27th Dec 2009 at 01:54
Poor earth, low input signal voltage, or, more likely for a cheap kit, one or more of the crimp connections on the HT leads is loose.
Posted 27th Dec 2009 at 02:09
skinnyman76
cheers guys ive emailed the company i got them from see what they say? i will try to meter the plug see what kind of power is running to them 1st then maybe try the earth if the powers ok...
pug power !!!
Posted 27th Dec 2009 at 02:58
NEVER measure the voltage going to a HID lamp as it could go over 20,000V when striking it but you can, of course measure the 12V input to the ballast.
Posted 27th Dec 2009 at 04:33
skinnyman76
no i meant the voltage from the oe headlight plug that feeds the ballast, guys sendin me 2 new ballasts under warranty see if it solves the problem..
pug power !!!
Posted 27th Dec 2009 at 18:50
Had this with my first kit, all connections were perfect, Never did it when new but it got gradually worse and worse the older the bulbs got untill one blew so i would say its a sign they are on their way out?
Replaced both bulbs after the first one blew and no more flickering.
Posted 28th Dec 2009 at 00:12
Discharge lamps used at work can flicker when cold and also for up to 50 hours when new until they settle down.
Posted 28th Dec 2009 at 04:34
skinnyman76
just got an email back getting a full new set sent out :-)
pug power !!!
Posted 28th Dec 2009 at 07:05
