Author Subject: Noise and now loss of power and weird sound??
tweedie
Hi All.
I have recently been having issues with my car where i heard a reasonably loud pop and now i have lost alot of power to the engine. It also now seems to sound like a Subaru on a bad day while i am driving about. A friend on mine told me that it could be the coil pack?
All help appreciated guys and gals i need my car back on the road ASAP.
cheers
Posted 20th Dec 2009 at 21:19
khj100
Sounds like either a misfire, caused probably by one of the coil packs packing up, or because the cambelt has slipped a tooth and timing is out.
You can easily check for the former; unplug each of the coil packs in turn and see if the car runs worse - if you find one that makes no difference, then that cylinder wasn't firing in the first place.
Posted 20th Dec 2009 at 21:37
Could it be a cracked plastic resonator below the inlet manifold?
Posted 20th Dec 2009 at 21:50
khj100
Good point John. Could well back that.
Could also just be a cracked exhaust or manifold.
How much power has it lost?
Posted 20th Dec 2009 at 21:54
Could be the head gasket gone as well between cylinders.
Posted 21st Dec 2009 at 02:21
tweedie
Gasket was done about 25k ago, surely wont go that quickly???
Posted 21st Dec 2009 at 19:25
Same issues as mine except mine is definately running on correct number of cylinders Yes
With mine, it only seems a bit lifeless under 3krpm, after that is fine.
Is there any sensors that when under 3k, ECU relies on data from said sensor, then after 3k, uses the ECU map?
Posted 21st Dec 2009 at 20:11
tweedie
I put my foot down in it today and it was SERIOUSLY lacking power. I took my foot off again virtually straight away as i didn't wanna do much damage!
Ordering a Coil Pack today Smile
Posted 21st Dec 2009 at 21:08
tweedie
Sorted, one of the coil pack clips for the connector had come off, now got temp fix on it. Runs SWEET now!! Jesus cos me nothing to fix THANK GOD this time of year!!!
Posted 24th Dec 2009 at 21:26
