displaying posts 376 to 389 of 389
Pages (16): first .. 14 15 [16]
Author Subject: Ben306 rallye thread
rallye1999
Post #376
are the windscreens still relatively available? mine could do with taking out and re sealing but id like to make sure they are available incase the inevitable happens.
Posted 18th Jun 2024 at 10:10
ben306
Post #377
When I arranged mine, it wasnt too bad, it was just something they had to arrange from warehouse stock so took a couple of days longer as it wasnt a screen they held in the depots anymore. but it was only a week later they were out fitting it so no real issues.
My 306 Rallye Project Thread
Lap of Anglesey Coastal
3 sisters circuit
Few laps at Blyton
Posted 18th Jun 2024 at 15:43
ben306
Post #378
Not updated for a long while so figured it was time to do so as there's been further progress from summer.
Got another trackday in at the 3 sister circuit
Usual ongoing maintenance
Stripped the parts car
Made a "footwell" lining as found after removing the sound deadening, My heal was catching on the seam between the floor and bulkhead
Attended a few shows and went to the rally show with Mark so a few rallyes on display at Oulton
Got one of my sets of wheels powder coated as they were due new tyres
3 sisters circuit
Few laps at Blyton
Posted 25th Feb 2025 at 11:56
ben306
Post #379
Trip back up to Knockhill in November
3 sisters circuit
Few laps at Blyton
Posted 25th Feb 2025 at 11:58
ben306
Post #380
Picked up another parts car for the bodies/ECU etc for mine
Got a trip to Oulton in in December
Then between xmas and new year, stripped down the parts car and started to get bits ready for the rallye
3 sisters circuit
Few laps at Blyton
Posted 25th Feb 2025 at 12:01
ben306
Post #381
After new year, I pulled the engine on the rallye and knew there was going to be some work to tidy up the engine bay. (I've keep cuts from the parts car) so cracked on with uncovering the rust, cleaning it all down, treating it, cutting out the bad stuff and making it good
Cut out and replaced the bad bits, replaced the chassis leg
Primed and painted up and ready to start putting back together
3 sisters circuit
Few laps at Blyton
Posted 25th Feb 2025 at 12:06
ben306
Post #382
Before and after comparisons
So fitted a PAS relocation kit, new belts, pulleys, water pump etc, lightened flywheel, Satchshift. ITG filter for the bodies etc
However just couldnt get the thing to run right (was using the engine from the parts car. Would idle, could move it around the drive etc but as soon as you put any real load on it, it would bog down and die.
Couldnt get to the bottom of it so just before a planned trip to anglesey, I decided to pull the engine to fit my original.. however I couldnt help but bolt the bodies onto it to see.
It ran, had a great day as a shake down for all the changes and stuff messed with. You could tell it needed mapping as a lot of flat spots and felt down on power over standard inlet etc.
3 sisters circuit
Few laps at Blyton
Posted 25th Feb 2025 at 12:25
ben306
Post #383
Some better shots from Anglesey last month
Some proper photos of the satchshift
Needed sorting out mapping wise as still wasnt right. Fitted a fixed 3bar FPR instead of the ebay special adjustable that was from the parts car and that made a massive difference to it straight away, but less of the slat spots through the rev range. Also fitted an air temp sensor.
But still sounded like the stupid pop bang maps all the chavs get on their golfs
So got it booked in for mapping at Waynes/ Chipwizards but figured Id modify the slam panel and fabricate an heat shield to try and maximise the cooler air getting to the bodies and stop some of the hot radiator air getting drawn in
The heat shield
3 sisters circuit
Few laps at Blyton
Posted 25th Feb 2025 at 13:13
ben306
Post #384
Finally,
Needed new tyres on another set of wheels so decided to get these powder coated at the same time. Figured Id go with something different
Its been in for mapping
Final power was 193bhp max, 176 torque. but more importantly it was 30 odd bhp increase from mid range where it matters.
Was mapped with the filter on (filter was off just to balance up the bodies)
initial run was 174bhp, once timing adjusted it was 183bhp with a near 20bhp increase mid range. then final runs where 193bhp and further 18bhp increase mid range.
Much smooth curve, and much better "under the curve" so hopefully I'll see a noticeable difference.
Still currently on standard cams/ original engine etc
Next trackday thats in the calendar is Croft in April but now itching to get something in before then to see how it is
3 sisters circuit
Few laps at Blyton
Posted 25th Feb 2025 at 13:22
ben306
Post #385
Another little update.
Cleaned up the mounting surfaces of the wheels after getting them powder coated and fitted them to see how they looked.
Had a "wobble" coming through the car at anglesey when I was loading up the front right of the car so decided to refresh some spare shafts and swap them over along with some spare hubs and replace the ball joints.
Couldnt wait until croft at easter to get it on track following it getting mapped so ended up booking a day at Oulton with it, happy with the bodies/mapping but its pretty loud now!
Unfortunately I killed the brakes, found in the afternoon the pedal was hitting the floor.
Time to give the brakes a overhaul, and flush out the fluid with fresh stuff.
Figured while they were off, I'd give them a sand down and fresh brush of paint
Rears weren't great either, found Im doing a set of rear pads every 3 trackdays or so. Nothing is sticking so cant figure it out. Anyhow I've a set of EBC pads/discs from a car I split that I've thrown on for now along with some painted carriers
Finally, I figured Id try and extend the brake ducting to get more of a direct feed to the brakes to help with cooling (previously they just fed into the arch area due to clearance etc). Its tight but hopefully it will help keep the temps a little lower.
3 sisters circuit
Few laps at Blyton
Posted 1st Apr 2025 at 08:50
Post #386
do you have a bias valve or the load compensator fitted?
Posted 19th Apr 2025 at 10:43
ben306
Post #387
Load compensator, its free and not seized so cant see that being the issue.
3 sisters circuit
Few laps at Blyton
Posted 22nd Apr 2025 at 12:05
monty-69
Post #388
Has the load valve been adjusted for the lowered ride height? Maybe modify it with washers or a spacer if it's not adjustable?
Posted 25th Apr 2025 at 04:04
ben306
Post #389
Yeah its been adjusted to suit. Strange thing is it was fine up until I had a sticking caliper a year or so ago.
Calipers have been replaced and everything refreshed but still going through rear pads every few trackdays.
3 sisters circuit
Few laps at Blyton
Posted 25th Apr 2025 at 08:18
