Author Subject: Early signs of head gasket?
justinaccurate
I havent been worrying about my car for a while but just wanted a second opinion on it
Recently Ive had quite thick white smoke pouring out the exhaust, doesnt seem to be just when I start it either
I have been a bit slack on topping the rad up (hasnt had any unusual stuff happen to the temp or heaters) and looked today - it was so far down I couldnt see it! Going to check where it is tomorrow when its light
And the last tank I did (without driving particularly hard) got 250 miles from 55 liters; would normally expect 300 miles from 50 Unsure
Are these things cheaper to fix if you catch them early? Time for a visit to carls?
Posted 18th Dec 2009 at 02:40
Better get it checked out asap mate Sad
At least if you do catch it early you have less of a chance of warping the head badly
Posted 18th Dec 2009 at 02:45
mabgti
NV motors
roland rat wrote:
Better get it checked out home(carls) asap mate Sad
Team Supercharged Gti-6
NV Motorsport
Automotive Performance Tuning
0121 448 7515
ECU Remapping/ DPF removal
www.nvmotorsport.com
Facebook Page
Project S6
Posted 18th Dec 2009 at 02:49
justinaccurate
Is the high fuel consumption a symptom of head gasket failure tho?
*edit* read that it can but only after misfire - doesnt seem much down on power and I dont think its missing Sad
Posted 18th Dec 2009 at 02:54
Not really mate.
Posted 18th Dec 2009 at 03:07
Mine went from a slight pink to two cylinders in 15 miles. I guess you might as well drive it until it goes wrong really, although I am wondering if i've burnt a channel in the head between the cylinders. Will find out soon - it will be back and better for the next 140k Smile
Posted 18th Dec 2009 at 03:13
darkgti6
Mine had blown between all cylinders and blown into the coolant system on cylinders 1 and 2 and it was still producing some decent power, enough that I was driving it around for ages before I got it up to CarlsLOL
Team Peugeot Sport 308 Gti�
Posted 18th Dec 2009 at 03:45
gti6girl
Dont forget to check the heat exchanger first, as this can cause head gasket symptoms!
Posted 18th Dec 2009 at 13:10
sprogeh
I thought that about mine, mines in garage atm, i suspected the heat exchanger, but bypassed that and still the same issue, my coolant water is all thick like milkshake and when i top it up it just dissapears, garage suspects head gasket or mabie liner seals???
Posted 19th Dec 2009 at 03:45
these engines are iron blocks without liners.
Posted 19th Dec 2009 at 03:47
t11hac
sprogeh wrote:
liner seals???
LOL
Team Black Rallye
Posted 19th Dec 2009 at 04:14
sprogeh
Must be my head gasket then, thanks i dont know much about engines. thanks
Posted 23rd Dec 2009 at 02:09
justinaccurate
I think I'm worrying over nothing. Fluid hasnt gone down since last week and smoke is not there when the car is warmed up.
Posted 23rd Dec 2009 at 14:30
mechanical_repairs
Bet its just the condensation in the exhaust and after a while it gets burnt off.
Teaches you for driving to the end of the road for the morning paper and back.
Carl
Posted 25th Dec 2009 at 17:33
justinaccurate
Yeah mate - my maccy d's run is less than 5 minutes, first I saw of this was when reversing on the drive after such a journey - dont normally see tat
Posted 26th Dec 2009 at 18:24
