Author Subject: Brake issue.
swifter gti6
The wife phoned to say her 306 had broken down
Wedding and portrait photography click here
Posted 16th Dec 2009 at 21:18
the engine cutting out is most likely because she stomped on the brake pedal without dipping the clutch Wink
solid pedal was possibly due to the ABS having gone mental, did RAC man do anything to the car?
Posted 16th Dec 2009 at 21:39
al4x
the engine hadn't stalled after the stop had it? sounds like a lack of servo assistance but it usually works for a few goes even after you switch off
Posted 16th Dec 2009 at 21:45
swifter gti6
She says she did dip the clutch although I suspect maybe she didn't.
No. He did nothing - its was fine when he got in and started it.
He said he thinks it may have been due to the servo from the engine cutting out.
Posted 16th Dec 2009 at 21:46
swifter gti6
Thats how she explained it - it stalled after she stopped.
Posted 16th Dec 2009 at 21:47
al4x
sounds like it went hard while it was still moving after stalling, women get a bit confused at times so probably best to say yes dear I'll get it checked. Take it for a razz and say its been mended Wink
sounds like thats what the RAC bloke thinks
Posted 16th Dec 2009 at 21:59
swifter gti6
Yes, the peddle went hard. The RAC bloke took it for a spin.
I am having the garage check the full brake system over on Friday. It could do with doing anyway.
Posted 16th Dec 2009 at 22:53
rallyestyle
My ex had this issue on her 306, when the car stalled the brakes didnt work Crazy I was always under the impression that brakes would work to some degree even if everything else shutdown? Unsure
Just Drive It
Posted 17th Dec 2009 at 18:25
They do, but you need to press the brakes harder.
Doesn't help if the check valve in the servo line isn't sealing properly though either.
Posted 17th Dec 2009 at 18:28
rallyestyle
Cool, thats what i was telling her at the time but she looked at me like i was some sort of spaz LOL
Just Drive It
Posted 17th Dec 2009 at 20:31
swifter gti6
She has gone out this morning and the peddle just goes straight to the floor almost. The brake works slightly but not well.
Same problem?
Posted 18th Dec 2009 at 14:28
shot M/C seals is the only suggestion I can think of.
Posted 18th Dec 2009 at 14:44
nicking your topic a bit, but i have just took my servo apart to clean it up, where/what is the "check valve", the spindle inside it? i haven't touched that but if something was worth doing i wish i'd have seen this sooner Doh the master cylinder seal on the reverse of the MC (inset) also looks ok but i did have a small drip from the join sometimes. cleaned it up best i can cos i don't fancy buying a new MC just yet LOL
might f*ck it off and run a diff pedal box, less problems Unsure
Posted 18th Dec 2009 at 14:53
the valve is that white bit the hose to the vacuum pump connects to.
Posted 18th Dec 2009 at 14:57
oh, so it's just a little 90degree plastic outlet connected via a rubber grommet i think. i pulled it all out and refitted it after, looked ok and sealed nicely.. we'll see when my brakes fail entirely.. Blink
sorry, ignore that, you mean the actual one at the pump Doh the white and black one with outlets on it with the direction indicator on it
Posted 18th Dec 2009 at 15:08
swifter gti6
Easy fix?
Ricky - get your own topicRazz
Posted 18th Dec 2009 at 15:22
Razz
the seal is discontinued.. see my MC thread not long ago.. new MC
Posted 18th Dec 2009 at 15:28
swifter gti6
Just checked and the fluid is very low.
Thats not something I have ever seen before.Unsure
Posted 18th Dec 2009 at 17:58
tom tom go
Tom Tom GONE!!
Have you checked all the brake lines for leaks or splits. One of the lines split on mine and it slowly lost its fluid over a couple of days, every now and again the pedal would go striaght to the floor then it would work fine. Eventually the pedal went to the floor and there was nothing at all, even after repeated presses.
Replaced the split line, new fluids and all has been well since. Don't know if this bare's any relevance but may be worth a check ?!
Cherry RALLYE
Posted 18th Dec 2009 at 18:23
Yeah, it's just a little plastic housing with a sealing disc and a spring in it - they do start sealing a bit intermittently over time though, so worth cleaning out if nothing else.
Posted 18th Dec 2009 at 19:37
swifter gti6
Traced the problem back to the Cylinder -
Posted 21st Dec 2009 at 02:22
what cylinder? master cylinder?
did they replace it for
Posted 21st Dec 2009 at 03:24
swifter gti6
I asumed master cylinder - its at the back.
Posted 21st Dec 2009 at 03:30
