Author Subject: Hard to start
jim01uk
Right got another 6 with a slight fault -
very hard to start when it's cold and has an occasional missfire when running, and the engine management light flashes occassionaly too.
CPS?
CTS?
Headgasket?
what else?
Posted 16th Dec 2009 at 19:10
stu
Could it possibly be a duff coil pack?
Posted 16th Dec 2009 at 19:20
spiros
Missfire and eng management light sounds like a coil pack to me - had the same on mine a while ago.
Get it plugged into a dyno to confirm .
PAUL
Posted 16th Dec 2009 at 19:24
stu
The same happened to mine, that's why I suggested it. Yes
No need to get it plugged in though. No
Just leave the engine running and then unplug each individual coil pack one at a time. If the engine starts to struggle with a coil pack unplugged then that one isn't faulty. If you unplug one and nothing happens then it is probably the culprit.
Hopefully some of that will make sense. Laugh
It's a free and simple check so it might be worth a try.
Posted 16th Dec 2009 at 21:19
jim01uk
more info:
We tried to read the fault but the engine lamp goes out before it can be read and it does not appear to store a code. We replaced the idle control valve and remade the poor vacuum pipe connections. The car runs fine when it does run, we did a full track day with it as it is and tried various things throughout the day. It has plenty of pull and runs smoothly when the engine lamp is out, there is no smoke or uneven running to suggest low compression and as I say, it does go too well to suggest a compression issue. It does tend to be worse at idle, when running from 2k revs + it's rarely has an issue.
Posted 17th Dec 2009 at 00:23
Lambda
Posted 17th Dec 2009 at 15:25
fletch
Track Head
Is it using any water? Oil and water clean?
Posted 17th Dec 2009 at 17:30
jim01uk
Not sure tbh. Its on ebay for
Posted 17th Dec 2009 at 18:28
Just buy my saxo you big hairy brute! LOL
Posted 18th Dec 2009 at 02:05
jim01uk
f*ck you and your battered saxo!
allesclar
linky for it???? Hyper
Team allesclar ®
Posted 18th Dec 2009 at 02:06
jim01uk
http://cgi.ebay.co.uk/1998-PEUGEOT-306-GTI-6-SILVER-GTI6_W0QQitemZ220527384267QQcmdZViewItemQQptZAutomobiles_UK?hash=item335874d6cb
Posted 18th Dec 2009 at 02:11
I'm sure you could fit an ass check each on the front seats LOL Flip
Posted 18th Dec 2009 at 02:46
mabgti
NV motors
you could work the whole clutch,brake and acc with your toes!
Team Supercharged Gti-6
NV Motorsport
Automotive Performance Tuning
0121 448 7515
ECU Remapping/ DPF removal
www.nvmotorsport.com
Facebook Page
Project S6
Posted 18th Dec 2009 at 02:47
justinaccurate
Thought you were going to say its blaze and I was going to say it's an XSi Shut up
jim01uk
LOL
Posted 18th Dec 2009 at 12:11
