Author Subject: Gaz coilovers - how much adjustment?
barryrob78
After fitting these to the 6 it still felt a bit 'rolly' so tried to stiffin it up a bit by adjusting them.
Fronts ok, turned them clockwise as far as they could go but the rears just seam to keep on turning in a clockwise direction!
If i keep turning will the valve come out completely or are they meant to take a huge amount of turns?
It was tight at first now it seams to move really easily...Blink
AX GT-XR2I-205 MI16-VX220-S2000-RX8-A4 Quattro-GTI-6-Clio 172
Posted 16th Dec 2009 at 02:26
~24 clicks on the rear IIRC.
The grubscrew fastening the knob on hasn't come out has it?
Posted 16th Dec 2009 at 02:31
barryrob78
It doesn't click at all when i turn it mate.
The screw is there with the gaz sticker on it and stating which way to turn (negative and positive signs)
They were not new, bought of a forum member.
Posted 16th Dec 2009 at 02:33
Nah, there's a little grub-screw in the side of that knob that holds it on the shaft.
Posted 16th Dec 2009 at 02:34
barryrob78
Oh ok.
You mean a screw you'd use an allen key to lossen/tighten? Like whats on the front struts to lower/raise the front end?
Posted 16th Dec 2009 at 02:37
Yes, very small one.
Posted 16th Dec 2009 at 02:38
barryrob78
Nice one, so when i get a new grubscrew you put it in as tight as possible then it should click when you turn the screw?
Posted 16th Dec 2009 at 02:39
Is yours missing then?
Doesn't need to be massively tight, but I'd stick a touch of loctite on it.
I'm trying to find my pictures of the bloody thing, got them here somewhere!
Posted 16th Dec 2009 at 02:41
barryrob78
Legend.
Think it must be missing with what you've said.
Im all scrubbed up now in the house, p*ssing it down outside, i'll check tomorrow.
It was both the rears that were not clicking...coincidental that both screws may be missing?
Sod it i'll go check....
Posted 16th Dec 2009 at 02:44
May be, might also be the needles in them are jammed if they've been on set on full stiffness + stood for a while.
Posted 16th Dec 2009 at 02:46
barryrob78
Just checked there are no grubscrews attached to the main screw or anywhere else on the shock.
I can't turn the screw by hand but it was moving easy with a set of grips.
Confused.
Posted 16th Dec 2009 at 02:59
Time for an upgrade I reckon Whistle
Posted 16th Dec 2009 at 23:30
barryrob78
They were an upgrade!!LOL ...may need another one though.
You may be right though, taking them back off and mechanic at work taking a look at them.
Posted 16th Dec 2009 at 23:34
I find it pretty hard to adjust my rears when they are on the car, but they aren't the same make.
Posted 16th Dec 2009 at 23:48
barryrob78
My problem is its too easy to turn the screw. Just doesn't seem right.
Posted 17th Dec 2009 at 00:43
I'll get you some pictures of the arrangement when I find them!
Mine are really easy to adjust on the car Adam Razz
Posted 17th Dec 2009 at 04:28
barryrob78
Thanks Adam. Need to get this sussed.
Cheers.
Posted 18th Dec 2009 at 00:00
Mine too, the click is'nt a positive on the rears as it is on the fronts though, if you are unsure if its working, take a shock off and wind all the damping off and compress then extend it by hand (crude but it should happen quite quick and easily) then wind the damping all the way on and it should be noticably slower. Count the turns or half turns and set them half way, then fit and go for a drive. If you need to adjust just evenly add more or less turns, the clicks just make keeping track easier but don't affect the damping action at all. Just hope the damper knob is turning the shaft mate, but I expect it will be. Hope you get it sorted Thumbs up
Posted 18th Dec 2009 at 00:08
vts_tibi
same here Big grin
VTS
best 60' : 2.272
Team Trackday™
Posted 18th Dec 2009 at 02:10
mabgti
NV motors
i had endless problems with the adjusters on the GAZ's. The clicks are not positive enough. Mine ere done with one key(knoCool not attatched to the adjustersNo
Anyhoo
ditched them and went for KW'sSmug
Team Supercharged Gti-6
NV Motorsport
Automotive Performance Tuning
0121 448 7515
ECU Remapping/ DPF removal
www.nvmotorsport.com
Facebook Page
Project S6
Posted 20th Dec 2009 at 20:23
vts_tibi wrote:
same here Big grin
Thats cos you have the better arrangement after I complained about them being hard to adjust Smile
Posted 21st Dec 2009 at 02:18
vts_tibi
hmmmmm.... in this case I owe you a beer LOL
VTS
best 60' : 2.272
Team Trackday™
Posted 21st Dec 2009 at 02:39
LOL
Posted 21st Dec 2009 at 04:14
Ta! I'll be round in 15 mins to collect Big grin
Posted 21st Dec 2009 at 04:23
Make it 30, he's adjusting the dampers first Whistle
Posted 21st Dec 2009 at 04:25
