Author Subject: Bilstein B8 Over-compressed
webster
I think i overloaded one of my rear shocks, this may seem like a stupid question to most but how can I tell if this is the case?
It doesn't seem to come back up as much as the other.. and that part of the car sits down a bit further...
cress87 wrote:
I'm stopped for speeding on a daily basis but now the police are aware that I live for the 306 they dare not interfere, just sit in their cars quaking as I drive past.
Posted 15th Dec 2009 at 21:24
webster
It may even be slightly wonky now if that spossible.
jimmyrallye
i bent a rear shock on my saxo vts when i wos moving out and put a washer machine in the boot LOL , only noticed when i changed the rear pads and discs
Posted 16th Dec 2009 at 01:49
webster
This was picking up those alloys from you lol
Posted 17th Dec 2009 at 02:55
The bumpstop should have took the impact out of it, unless they're tired.
If they've hit then the shaft may be bent slightly, or the piston would have impacted the body, take it off and stroke it up and down as fast as you can and tell me what it feels like.
Posted 17th Dec 2009 at 04:31
cress87
Unsure
Posted 17th Dec 2009 at 04:35
Doh
Minds out of the gutter people* LOL
*Well, those of you with ones big enough to find
Posted 17th Dec 2009 at 04:37
webster
philipm i took a pic you got msn or something? webzta@hotmail.com
Posted 17th Dec 2009 at 05:05
Nah, e-mail it me.
Posted 17th Dec 2009 at 05:06
webster
Sending now mate, they're not the best pictures ever but maybe you can see...
Posted 17th Dec 2009 at 05:12
webster
this is how low it went when I collected the wheels from jimmy - drove back 2 hours ish maybe 3.
pic of shock
also the little spring thing sits down/looks pressured, other side looks fine ;/
Posted 17th Dec 2009 at 05:16
Hmm, can't really see, but there's no fluid leaks there, and the bottom bolt looks straight - normally it'd bend a touch.
Bumpstop has hit the arm hard though.
It could be bent and holding the arm down I suppose, but I'd check you haven't sheared the bolt in the ARB end-plate first, it's been known to happen before.
webster
If you can explain in noddy terms what I can do/try that would be good :-)
Posted 17th Dec 2009 at 05:17
Take it off and see what it feels like, check under the cover to see if the shaft is bent or the seals are weeping.
Posted 17th Dec 2009 at 05:42
its too fecking low and you've broken it Thumbs up
Posted 17th Dec 2009 at 16:05
webster
it was setup 30mm, picked up some wheels for anth (5x17 + tyres, + 3 people.. :/ )
Posted 17th Dec 2009 at 18:49
mxcrazy
Its not just a horribly shagged beam is it? bearings fallen to bits and making the trailing arm really stiff to move?
Posted 17th Dec 2009 at 20:15
webster
Rear beam was rebuilt by skip browns about 10-20k ago.
Posted 17th Dec 2009 at 20:25
webster
Will try get the shock off this weekend with some help from someone and see what state it's in.
Posted 17th Dec 2009 at 20:26
