Author Subject: rear brakes binding?
nick205gti6
I noticed recently that there is a grinding noise coming from my rear brakes. I think they have been binding for some time and have worn the pad down really quickly.
One of the pads is now completely missing!
I've just bought new disks and pads but what causes the binding?? and how do I free them up?
1990 205 GTI-6
Posted 14th Dec 2009 at 23:47
I had the same problem. After changing the handbrake cable it still happened so changing the caliper cured it.
Posted 15th Dec 2009 at 05:32
puglover Banned!
the sliders or handbrake mech cn seize up as said prob new caliper or some grease might help.
Posted 15th Dec 2009 at 05:38
nick205gti6
I suspect its the caliper thats seized then. When I set off from cold and release the handbrake its fine, when I come to a junction it grinds after I've released the footbrake.
hopefully I can clean it up with a wire brush and grease it. are there any guides or kits you can use to refurbish them?
or diagrams on how the calipers operate?
thanks!!
1990 205 GTI-6
Posted 15th Dec 2009 at 17:49
nick205gti6
well ive found this;
eBay link
is it easy to refurb them? any guides?
also what causes them to seize, heat? or brake dust?
1990 205 GTI-6
Posted 17th Dec 2009 at 00:00
tvrfan007
It's pretty easy to refurbish the calipers, and in my experience they're rarely beyond repair.
Firstly, strip the carrier down and remove it, take off the disc and get a better look at what you're dealing with. The piston boot might be split, the piston will likely be dry of grease, and the sliders have 4 boots that should all be inspected for splits. I would advise you to buy a pot of red rubber grease if you don't have any, and pack the sliders and piston boots with this - try and clean as much dried out grease up as you can.
Wind the piston right out for easiest cleaning. Smile
I'm Si btw Tee hee
Night Blue VW Golf GTD
Posted 17th Dec 2009 at 02:01
nick205gti6
thanks tvrfan007.
sounds easy enough so I've just ordered one and some red rubber grease!
1990 205 GTI-6
Posted 17th Dec 2009 at 02:13
When you take them apart you will notice an angled piece that is held in by two spring clips, this gets rusty and can cause the pads to stick. When you remove it to get the pads out, clean the rust off it with a file or replace it, and when it cones to fit it again, use some copper grase on all the parts the pads slide on. Not too much as you don't want any getting on the friction surfaces but you get the idea.
Posted 17th Dec 2009 at 03:30
nick205gti6
right the kit arrived today.
lots of parts and i only know what a few do!! anyone identify the others?
as far as copper grease I've heard one garage saying they arnt using it at all now as its not good for the rubber etc and are using a a non metallic subtetute?
1990 205 GTI-6
Posted 19th Dec 2009 at 21:03
rich-6
It'l be lithuim Cool
Cool
RIP Pete Sims
Posted 20th Dec 2009 at 00:35
Lithium's a metal so could be a compound of it?
Posted 20th Dec 2009 at 01:35
rubber brake grease, look for a brake grease that doesn't contain copper basically Smile
Posted 22nd Dec 2009 at 16:11
It'll probably be ceramic or silicon-based
Posted 22nd Dec 2009 at 17:20
tvrfan007
Agree with the above it'll likely be silicon based. Smile
Red rubber grease served me ok. Smile
I'm Si btw Tee hee
Posted 22nd Dec 2009 at 17:41
