Author Subject: Oil temp
lingl9z
Hey all, what temp should the oil temp gauge sit and and how long does it take to reach that temp? after a 20min drive (not hammering it at all mind) it goes to around the bar before the 90? is that correct, I've never seen it at 90.
Posted 14th Dec 2009 at 04:01
khj100
Yup. Should get there much quicker than 20 minutes though!
And rapidly up to 130 if you start abusing it in warm conditions!
Posted 14th Dec 2009 at 04:06
lingl9z
Strange, any idea why it takes so long? the engine gets to temp pretty quick since replacing the stat and finally getting it to bleed, just the oil takes a while...
Posted 14th Dec 2009 at 04:07
What oil is in it?
Posted 14th Dec 2009 at 10:08
I let my oil warm up by driving under 3000rpm for the first few miles of the journey. Starting from cold it takes about 10 minutes or so to get upto temp (just below 90).
When I was at Rockingham at FCS (hot day) after about 4-5 laps my oil was hovering round the 130 mark Unsure
Posted 14th Dec 2009 at 15:14
lingl9z
strange indeed, what would be the reason for it taking ages to get to temp (oil only)
Not sure what oils in there as the previous owner done a service before i got it off him.
Rich.
Posted 14th Dec 2009 at 15:48
never taken note of how long mine takes, but it's a lot longer with fresh total oil in it.
I'd guess about 10 minutes unless I drive it harder then it'll be warm within 5 Smile
Posted 14th Dec 2009 at 16:13
spike_uk06
Today it took a good 10miles before the oil got to temp. I would say it's normal? Dunno
Team China
Team Pirelli
Team Cracked Bumper
92k
20th Nov 1999 she was born
Posted 14th Dec 2009 at 17:17
lingl9z
Hmm guess that probs is normal then ! think i'll get an oil pressure gauge in at some point as I've always used them to judge how soft/hard to drive =] Cheers for all the help guys.
Posted 14th Dec 2009 at 19:01
Rich E Forum Admin
There is quite a lot that can affect the oil temperature and you may indeed find the temperatures you
Posted 15th Dec 2009 at 19:16
lingl9z
Thanks for that Rich, very helpful indeed, I shall take a look and see if i have an undertray when i get a chance, if not start looking at other aspects, I know the rad i had is old... really old.. looks asthough its had some leaks at some point.
Also while on the subject of 'oil' when you turn the ignition on and the lights come on just above the oil temp red and white, I take it thats a level indicator?
thanks again
Rich.
Posted 15th Dec 2009 at 21:55
It is indeed. Yes
Posted 16th Dec 2009 at 03:19
jackcross1989
just searching through various threads as my oil temp never really goes above 90, but yesterday went up to about 100, is this bad for oil temp to be high , as i see someones had it at 130?
or is it fine?
cheers
Posted 19th May 2010 at 22:57
According to my engine guru, engines should ideally never exceed 70 degrees for coolant and 80 for oil, sounds low, but thats more than hot enough for the engine tolerances to be right, so engine wear will not be an issue at those temps. This is a race engine we are talking now but the same principles apply. I'd be trying not to let my coolant ever get above 80 in a road car, and be trying to keep oil between 80-90 when driven hard. People running near the 130 mark are asking for trouble. Trust me, I found out the hard way. Film strength is greatly reduced at those temps and unless you are using really good quality oil and changing it very regularly it won't retain its protective qualities for long.
Posted 19th May 2010 at 23:11
jackcross1989
cheers davey boy, i have some tell tale signs of an engine mount gone aswell, as seeing as your in the same area as me i mite get into contact soon cheers
Posted 20th May 2010 at 01:02
We can check it in about 10 minutes if you need a confirmation on that. Thumbs up
Posted 20th May 2010 at 01:15
