Author Subject: Cold Starting Issues
scott8629
Hello Guys,
My poor beloved Rallye has developed a cold starting issue. It takes around one minute of cranking the engine for it to splutter into life then all is fine after that, It will start as usual when the engine is warm.
I have replaced the CTS and stepper motor recently.
I will change the air filter, plugs and HT leads next week (anyone know a good/cheap supplier?).
Anyone have an idea about this? Anything else I should change?
TIA
Posted 3rd Dec 2009 at 13:11
do you have any temperature issues? is it misfiring when it runs from cold before clearing up?
Posted 3rd Dec 2009 at 13:38
scott8629
Maybe for a short time, but nothing major.
Posted 3rd Dec 2009 at 14:12
khj100
Hopefully it's just electric (CTS or crank sensor would have been my guess), but I have (sorry to say) seen this problem when the headgasket is on the way out.
I'd check cylinder compressions to be sure.
Also, Rallye doesn't have HT leads so you can save yourself money with them!
Posted 3rd Dec 2009 at 14:32
scott8629
Doh! Whats the price for a head gasket change?
Posted 3rd Dec 2009 at 14:36
mechanical_repairs
As Kev has said above, see where the coolant level sits as if its low thats another indication, get the cooling system pressure checked, if the pressure slowly drops after a while and there is no visual leaks then you may be into head gasket territory.
After a pressure test start it up, it will missfire for a breif period then after a blip of the throttle will clear itself, this will be due to one or more of the cylinders having a coolant mist in it.
Carl
Posted 3rd Dec 2009 at 14:38
mechanical_repairs
Carl
Posted 3rd Dec 2009 at 14:41
scott8629
Just had a look and the coolant is quite low, I will top it up and monitor it.
I was stuck in traffic for 2.5 hours the day before this started but the car never overheated? So this may have caused it
I have just started it up and it took maybe 10 seconds to fire up, Then left it 10 mins and it fired up as usual. Why is this?
I dont know what to do if the HG has gone. Maybe time for another car....? Golf R32?
Posted 3rd Dec 2009 at 17:33
just fix the hg, not a problem really. do a comp test first though, that was why i asked in my first post about temperature as this is what my old 8v xsi had and it was early signs of HG failure
it could be something tiny though aswell but you have to look at everything else first before buying parts. do the tests first before splashing out on sensors
Posted 3rd Dec 2009 at 17:38
birk
My headggaskets on its way out then LOL
Dimma + Gt35 turbo = Ninja
Solid rear beam mounts £130
07889376885
Dan
Posted 3rd Dec 2009 at 18:48
