Author Subject: Coolant system won't bleed
cwspellowe
Urgh now I've fixed the fans I've got another problem.
Basically I've been trying to bleed the coolant system. the rad and thermostat have bled absolutely fine, but the top bleed point behind the heatshield won't do anything. I've followed the guide word for word with the header tank but no water comes out even after an hour. the water level doesn't even seem to drop in the header tank.
I know there's an airlock there cos the heating is on the blink but I can't bleed it for the life of me.
also about a litre of coolant is disappearing every month. could be a leak somewhere upstream? but if so its only losing 30ml per day which isn't much, and surely not enough to prevent the system from bleeding..?
suggestions please lads Smile
Bye bye Sundance Kid Sad
Posted 3rd Dec 2009 at 02:06
have you tried taking the screw fully out of the pipe? sounds like you may have a blocked pipe or worse a blocked matrix.
Posted 3rd Dec 2009 at 02:29
cwspellowe
just had a think regarding the loss of coolant, blatantly the heater matrix. I've had a ridiculous amount of condensation on the windscreen for a few weeks. I guess I answered my own question there...
now just how to bleed it..?
cwspellowe
yeah screw was all the way out. I'll try and jimmy the bleed pipe tomorrow
oh and don't think the matrix is blocked, it blows hot air for about 10 seconds so something warm is getting to it, but if it's just hot air. I'm guessing that's why it goes cold so quick?
Posted 3rd Dec 2009 at 02:34
possible that it has been radwelded up Doh
Posted 3rd Dec 2009 at 02:33
cwspellowe
funny thing is the previous owner made a thread about the same problem 2 years ago, guess he never fixed it....
Posted 3rd Dec 2009 at 02:36
mr2swzo
I had a problem recently with the matrix bleed point too. I took the screw completely out and no coolant came out. It turned out that the pipe was blocked by gunge and i simply used a long nail to scrape out the gunge and hey presto, coolant came through.
Hope you fix it soon, it's a bad time of year to have no heat! Not to mention the damage it may do to your engine.
Posted 8th Dec 2009 at 04:38
spaniel
have you tried gently applying some revs, i had this problem and it cleared it fine for me
Posted 10th Dec 2009 at 01:28
jeffers Forum Admin
If your getting condensation, 100% heater matrix gone dude!Sad
Team Running Engine again!
Team Negative Camber!
Posted 10th Dec 2009 at 04:59
c_j_m
2ltr bottle in the rad with the top cut off.
Rases the water above the bleed point allowing to to be bled properly.
Posted 10th Dec 2009 at 06:59
cwspellowe
c_j_m i've followed the bleeding guide to the letter. I'm siding with jeffers, i think the matrix is f*cked Sad
Posted 10th Dec 2009 at 20:24
mike306
Better wrap up warm matey Razz
High boost '6 for weekends
406 2.1 Executive for weekdays
Posted 11th Dec 2009 at 05:21
c_j_m
It'll still bleed all the air out even if the matrix is leaking slightly.
Just if its a really big leak it'll let the air in.
Posted 11th Dec 2009 at 05:43
r*byb
Where is the guide your following ? i need to totally drain mine on Saturday.
Team Low Compression
Posted 16th Dec 2009 at 05:12
