How much should I have taken off my flywheel when I have it skimmed?
Thanks,
| Author | Subject: Flywheel skimming |
cabbymeg
Regular Location: Alfreton/Derbyshite Registered: 04 Sep 2009 Posts: 323 Status: Offline |
Hi all, How much should I have taken off my flywheel when I have it skimmed? Thanks, Chris |
depends how much like a pringle it is.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
As little as possible to clean it up, if it needs a fair chunk off, then the relief will want machining too to keep the preload the same on the pressure plate.________________________________________ - Bespoke rollcages/additions/adjustments. Half cages right up to complete custom spaceframes - MSA/FIA spec, CDS, ROPT, T45, etc - PM meEmail me! Custom-made polybushes available - need an odd size or fitment? - anything from batch work to one-off pieces. |
cabbymeg
The relief? What's that? |
The bit the clutch cover bolts to.________________________________________ - Bespoke rollcages/additions/adjustments. Half cages right up to complete custom spaceframes - MSA/FIA spec, CDS, ROPT, T45, etc - PM meEmail me! Custom-made polybushes available - need an odd size or fitment? - anything from batch work to one-off pieces. |
chris with a pug
Seasoned Pro Location: Southampton Registered: 16 Feb 2003 Posts: 5,366 Status: Offline |
I had to have mine skimmed a few years back, the clutch went again scoring the fly wheel and they couldnt skim it again as there is only so much you can take off. |
andrewrallye
Newbie Location: Swansea Registered: 01 Oct 2009 Posts: 50 Status: Offline |
To clean up the clutch face, make sure that they are going to surface grind it as opposed to turning it on a lathe. In use you can get very hard spots on the flywheel, especially if the clutch is slipped a lot. When trying to skim the face on a lathe the tool jumps over the high spots, so you don't realy achieve much. This only applies to the face, a lathe will be ok for the rest of the work, lightening etc.________________________________________ E reg 205GTI non sunroof maybe for sale m.o.t'd ideal rally, trackday car, also have 6 engine and box available |
