Author Subject: Shock Absorber Bush?
oecken
As above, what is this (If such a thing exists)
and if it is knackered, does this mean i will need to replace the shock(s) as there not cheap ones Sad
hope this makes sense!
Posted 25th Nov 2009 at 21:10
On the rear damper? The rubber bushes that the bolts go through at a guess, you can buy them individually to replace if the damper is OK.
Posted 25th Nov 2009 at 21:13
oecken
tbh Phil im not too sure, Garage stated that the rear shock absorber bush.... is pretty knackered, and that hes not sure if they can just replace the rubber bush or if it will need a new shock (as its not on the standard shocks) Avo as its on avo coilovers on the front.
the garage are not going to be doing it (Lack of funds on my part) but il need to know for it to be sorted! i should get more of an explanation when i get the car back tomorrow, but does that make any sense for now? (only went in for a bloody service! needs that, new ball joint, 2 tires Sad Love french cars lol)
Posted 25th Nov 2009 at 21:19
They just press out, if you ring Avo or Gaz they'll supply you a new bush, they should be polyurethane on those?
Posted 25th Nov 2009 at 21:39
oecken
Right okay! cheers Phillip
so just to get my head round it (not mechanically minded when it comes to the rear end of a car, strangely..)
But i know the Car is on Avo "suspension" adjustable coilovers at the front, what would be on the rear... Shock / dampers .. Sorry for the retarded question LOL
Posted 25th Nov 2009 at 22:10
have a peek under, you will find out Razz
Posted 25th Nov 2009 at 22:14
Just some dampers, two round bushes in either end, like the Gaz ones here:
Posted 25th Nov 2009 at 22:16
Any chance you get phil - you whore...
Here you can see the top bushes on these two shocks Razz
Posted 25th Nov 2009 at 22:45
Top bushes Adam, what are they? Razz
And your remote reservoir has fallen off Shock Whistle
Posted 25th Nov 2009 at 23:09
oecken
you say that but i wouldnt know what i was looking at LOL
cheers guys, makes sense now, was hoping new shocks wouldnt be needed!
Posted 25th Nov 2009 at 23:13
if they're AVO they'll be shineee black, and say AVO on them....
originals are a satin black steel body, and have Peugeot stamped into them....
Posted 25th Nov 2009 at 23:42
If they're AVO they should look very similar to the Gaz ones, just black, almost the same design bar the internal shims.
Posted 25th Nov 2009 at 23:47
oecken
indeed they are Avo, as are the front Thumbs up ta
Posted 25th Nov 2009 at 23:55
