Author Subject: Overheating?
asim_pug306
I've got a 1.8 XS and it the temperature gets quite high everytime I'm stood still for over 2 or 3 mins, basically in traffic. Goes up to about 95-100 at times.
I've read that its normal for the 6 and rallye but I was wondering if the 1.8 is the same.
What temperature should the fan come on? Doesn't ever seem to come on
'01 Astor Grey GTi6
'99 Cherry Rallye
Posted 21st Nov 2009 at 06:35
cwspellowe
First and foremost..
check your coolant level?
Bye bye Sundance Kid Sad
Posted 21st Nov 2009 at 21:15
asim_pug306
Coolant level seems fine. No signs of any oil in there either so doesn't seem to be anything major.
I just thought it could be a dodgy sensor not setting the fan off?
'01 Astor Grey GTi6
'99 Cherry Rallye
Posted 22nd Nov 2009 at 01:22
ballys16
XSi 8V -> S16
Posted 22nd Nov 2009 at 01:50
asim_pug306
So as long as it doesn't go over 97, it's pretty normal
'01 Astor Grey GTi6
'99 Cherry Rallye
Posted 22nd Nov 2009 at 02:13
ballys16
I think it is a bit mental, and depends heavily on traffic conditions as well as the weather.
XSi 8V -> S16
Posted 22nd Nov 2009 at 02:20
asim_pug306
It does it in all weather conditions and as soon as the car is stationary for around 2 minutes, it just shoots straight up
'01 Astor Grey GTi6
'99 Cherry Rallye
Posted 22nd Nov 2009 at 03:22
ballys16
Warming up when stationary is OK.
When at ~100 C (depending on the gauge precision) you should hear the fans kick in at low speed (or see them if you open the bonnet).
If they don't then there is a fault to find.
Until you find out, you can always use the AC (if the fans do work).
XSi 8V -> S16
Posted 22nd Nov 2009 at 03:37
ant_kernow
,ime kicks in just below the red?
team umpalumpa.
Posted 22nd Nov 2009 at 03:52
ant_kernow
sorry mine i ment!
team umpalumpa.
Posted 22nd Nov 2009 at 03:53
asim_pug306
Cheers for the help guys
'01 Astor Grey GTi6
'99 Cherry Rallye
Posted 22nd Nov 2009 at 04:15
ballys16
ant_kernow wrote:
sorry mine i ment!
Sorry, I am only familiar with phase 1s, and there is no red there. 110 C is still in the "safe" zone, with two more lines to go. I would be nervous if the needle was always above the 110 C line. Specially in winter ...
XSi 8V -> S16
Posted 22nd Nov 2009 at 04:52
