Author Subject: Arb end plates
Are these the same on both sides? I have an old one off my other beam and will be fitting my hybrid soon and no for a fact one of the plates on my arb is seizd at the mo
Posted 16th Nov 2009 at 10:18
nope, different left to right 30 splines in one 32 on the other, but the same on all 306's/xsara's.
the nearside plate is drawn fully onto the ARB, the offside is drawn only as far as required to set the clearance against the seals.
Posted 16th Nov 2009 at 15:15
Oh man! Hammer job then i guess?
Posted 16th Nov 2009 at 16:53
New one is 40quid Huh?
Posted 16th Nov 2009 at 16:55
monkeyman
Soak in some diesel? seems to free up stuff.
Forum Search Clicky
Posted 16th Nov 2009 at 18:01
12mm x1.5mm pitch threaded bolt well greased wound in the end, job jobbed.
why would you buy a new one? they're the same on all 306's and xsara's, hence in plentiful supply.
Posted 16th Nov 2009 at 18:32
iplay
WHy is thre a different number of splines? surely the ARB can be inserted either way?
Posted 16th Nov 2009 at 18:55
because the arb has a different number of splines on it Razz
in truth, scoobydoo LOL
Posted 16th Nov 2009 at 19:04
monkeyman
I think the trailing arms are different each side for some French reason Crazy
Forum Search Clicky
Posted 16th Nov 2009 at 19:27
not with regards to the ARB they arent.
Posted 16th Nov 2009 at 20:51
