displaying posts 1 to 25 of 45
Author Subject: Yet another tapper/ticker...
joshy
I really am sorry to post this. I know that there is already a 'tapper' thread on the first page, and the subject has been asked loads of times before (I did search!), but...
I recently bought a GTi-6 powered 205. Local, Professionally converted, rebuilt bottom end, cheap and most importantly, it was black. Let's just say I got very excited. So excited in fact, that I didn't pay too much attention to the 'slight tapping from lifters' with in all fairness was mentioned in the ad. Apparently the tappets/lifters (what is the correct wording for them anyway?) were recently replaced, so at best they just needed 'bedding in' and at the absolute worse it was an 'old' engine and a bit of excess noise is to be expected.
For the 3 weeks I've had the car, it has been noticeable, but not to the point where it has annoyed me enough to even think about doing anything about it, anyway the Stereo and Fart can exhaust do a very successful job of drowning it out.
I signed up here the other night out of sheer interest, and then stumbled across one of the many 'tapper' threads, then I read the words 'bent valve' followed closely by 'It could snap off at any moment and wreck the entire engine' (paraphrasing)... Then I got ever so slightly worried LOL
I'll be replacing the spark plugs (and checking that they are tight!) later on in the month when it's time for a service, but deep down, I have my doubts that it is something that simple. Although the noise can be described better as a tick, it does increase and decrease with engine speed, until about 3,000RPM when it seems to get slightly quieter, but I cannot hear much after that other than the exhaust drone!
Now I noticed something the other day. It doesn't tick until the car has warmed up slightly (5 minutes of driving). Oil thins as it heats up, so this has got me thinking that perhaps I the oil I'm running may be too thin? Could the Lifters/tappets maybe need to 'bed in' like I initially thought(although thinking about it, it is probably unlikely!)
If the worst comes to the worst and it is a bent valve, What is the likely hood of dropping a valve? Is it simply a matter of soldiering one and keeping the AA card close to hand at all times? Am I mad for considering doing some track days with the engine in it's current state?
A head rebuild isn't financially going to happen for at least a few months, and even then I'd like to have the money to go to town with the thing whilst it is in bits (flowed, ported, liary cams, TBs Love). And it NEEDS to be used Mon - Friday
Any thoughts guys? Any advice is much appreciated
Posted 12th Nov 2009 at 03:54
smegal
If it is a bent valve there is no way of knowing if it will drop.
Here are two videos of my car (a tapper at that point)
video1
video2
It is hard to tell from a video though as sound never comes across that well but it should give you an idea.
Usually a replacement engine is cheaper than a rebuild (providing you can fit it yourself)
One thing I will add is, as far as I know the lifters on these don't really fail. Mine have been noisy before but it is literally for a few seconds after starting the car. (Fully synth oil sorted this though)
Ex SC-6
Now in a Megane R26
Posted 12th Nov 2009 at 04:11
joshy
Thanks for the reply!
It's odd, I saw the videos the other day and I'm still convinced mine sounds more 'tinny' than yours did, but the guy who did the conversion has just come back to me saying that he thinks it's bent valves on the inlet side. Sort of shoots my hopes it was loose spark plugs out of the sky LOL.
Correct my ignorance, but is there any reason I could not simply only replace the bent valves, rather than doing a rebuild (other than the obvious, you should do it whilst you're in the area)?
Posted 12th Nov 2009 at 04:19
there'd be nothing wrong with just taking the head off and getting the bent valves replaced, though there will often be some damaged valve guides, any decent head machinist would be able to rectify those for you, use a new gasket of appropriate thickness (use a thicker one to compensate for any skim)
the main problem is that the inlet valves cost about
Posted 12th Nov 2009 at 04:23
pete-gti
Bent valves tick straight away from cold ? You say dont start ticking to after 5 minutes etc !
Posted 12th Nov 2009 at 23:42
joshy
I'd be interested in hearing more discussion on the delay of tapping? It does make sense that they'd tap from cold, but they absolutely don't until a bit of use
Posted 14th Nov 2009 at 17:05
aaron6
My old 6 tapped. Was indeed bent valves. But it did do it from cold and got louder as the car got hotter. I had it fixed and after a few thousand miles the water pump failed and caused it to tapp much worse. Still, it was noisey from cold and worse when hot but it also missed a lot was down on power. If yours dont tap from cold i cant see it being bent valves. Maybe noisey injectors. Could a broken spark plug cause a tappy noise? As in, maybe they are tight but gas is still escaping? Dunno though, just mulling.Smile
Posted 14th Nov 2009 at 19:46
monkgti
this is exactly the same as my 6 i actually posted a thread about it, when its cold its perfect not one bit noisy but when it gets hot or if i give it a good hard drive theres a slight tapping sound and its most noticiple between 1000rpm and about 3000 above that it cant really be heard, but im pretty sure it cant be valves or anything as they should tap wether hot or cold, i was thinking mabey needs a different grade oil??? im using 10w40
IF YOU CAN READ THIS IM STILL IN 5TH!!!
Posted 14th Nov 2009 at 20:27
aaron6
Nah mate, 10/40 whats meant to be in it. I do think it may be worth pulling out the spark plugs and visually inspecting them for cracks maybe. All i will 100% commit myself too though is that true tappers tap from cold. Also, i used to have a powerflow exhaust with was excessivly loud, yet i could still hear mine (both times) up through the whole rev rang.
Posted 14th Nov 2009 at 22:17
gazzerdaman
Bet it has got magnatec or something in it.
If it doesn't tap from cold it's definetly not a bent valve.
I vote shit oil.
It could be the timing slipping slightly when its warmer, but I would expect the tap to be permanent now.
Gary
Cherry Red GTi 6
Posted 15th Nov 2009 at 04:46
aaron6
I vote shit oil.
It cant slip when its warmer and slip back when its colder. I guess it could be shit oil. When its warmer its thinner which may cause problems. Magnetec is okay though. Its what i used. That and GTX. Never caused me any any issues. Maybe its too old though. Or the wrong oil totally.
Posted 15th Nov 2009 at 07:14
monkgti
its valvoline 10w40, and i always flush the engine and change it every 5,000miles at most, also ive used this oil in nearly all my cars inc 106 gti and scooby wrx and its always been very good in them never even going black or close to it when being drained out at service time and never burning a drop either, do any of ye use this oil in your 6? i was thinking that mabey because the 6 actually seems to me to be a fairly hot running engine that mabey it needs a different grade oil? what i was thinking of trying is next service going to pug and getting the total oil from them which is recommended and trying that in it? by the way the tap is definitly not in it when shes cold or just barely warming up, just tried it tonight again and it didnt come into it until she was fully up to running temp and then just stays in from idle up to nearly 3,000 then cant hear it at all...
Posted 15th Nov 2009 at 08:57
Rich E Forum Admin
What's the point? A good semi-synth like that you can leave in for at least 15k. With the newer filter design the recommended change interval is 20k.
Posted 15th Nov 2009 at 19:33
monkgti
i know it doesnt have to be changed that often but i just always like to change my oil around that many miles especially since id usually be driving the cars fairly hard and apart from that its a cheap thing to do aswell, i just feel better changing it often...
Posted 15th Nov 2009 at 19:59
joshy
I vote shit oil.
Interesting!
By all means it doesn't run for very long without tapping, buty for the first 3-5 I certainly get nothing. Well, nothing that I can hear from the cabin at least.
It has had a recent oil change, but I'll do it again to be 100% sure (as well as checking the plugs). Any ideas on oil? I've heard that 10w-50 stuff recommended. Could I maybe get away with Mobil S 10W-40, as I get that free at work (as well as Mobil 1 fully synthetic 0W-40, but I dare say that'll be far too thin?)
Would using her out on track be a terrible idea if worst being the worst and it is a bent valve?
Posted 15th Nov 2009 at 20:53
Rich E Forum Admin
Mobil 1 0W-40 is absolutely fine Yes
In fact, it is closest match to the OE specified oil's viscosity at operating temperature.
Posted 15th Nov 2009 at 21:04
pete-gti
So we all agree not bent valve then ?
Posted 15th Nov 2009 at 21:30
chas
Maybe I'm wrong but I'd personally have said that 0W40 is too thin, with 5W40 being a better alternative.
As long as your engine doesn't sound like this you don't have much to worry about LOL:
http://www.youtube.com/watch?v=HnQwkcIsVAg
Ex Owner of 2000 Phase 3 306 GTi 6 China Blue - You shall be missed
1974 Triumph Stag
1989 Peugeot 205 GTi 1.6
2003 Alfa Romeo 147 JTD Lusso
2005 Mondeo Ghia X 3.0 Estate LPG
Posted 15th Nov 2009 at 22:50
Rich E Forum Admin
chas wrote:
Maybe I'm wrong but I'd personally have said that 0W40 is too think, with 5W40 being a better alternative.
Roll eyes
You are wrong Yes
At temperatures you will encounter in the UK they are exactly the same thickness. The only difference is that the 0W-40 remains pourable at a colder temperature than the 5W-40.
Posted 15th Nov 2009 at 22:14
aaron6
I, and a lot of people use 10/40. It is fine to use. And if you get it free, bonus!
Posted 15th Nov 2009 at 22:51
chas
It's not like the GTi-6 is a modern engine though. It can trace its roots back to the T16 and the design itself is now getting on for 15 years old. Even in the Porsche cirles, a few people have had perfectly good engines finished off by 0W40 when they were fine on 10W40 and 5W40. Ask on the Fiat Turbo forums and you'll see a similar pattern emerging.
I know the UK is cold, but I wouldn't have said it was 'That' cold.
1974 Triumph Stag
Posted 15th Nov 2009 at 22:54
ballys16
Agree - weather here in Hungary can be as low as -15/20C in winter and summer as warm as 35/40C.
Even under such circumstances 10W40 oil is fine.
For winter some do go for 5W40 and 10W60 for summer - but if 10W40 is used and renewed with the OEM filter at the correct intervals I wouldn't imagine that as being the root cause for engine failure.
XSi 8V -> S16
Posted 15th Nov 2009 at 23:47
pete-gti
For sc6 etc maybe 0w10 fully syn is best bet?
Posted 16th Nov 2009 at 00:50
allesclar
10W50 or 20W50 fully synthetic is the recommended oil for a charged 6'
Team allesclar ®
Posted 16th Nov 2009 at 00:58
pete-gti
i no few use 10w40 semi synthetic on sc6's . ive gfot 0w40 fully in at moment ! so seems like theres a right mix bag
Posted 16th Nov 2009 at 01:12
