displaying posts 1 to 25 of 34
Author Subject: Some internals advice from a newbie...
darrenjlobb
Hey guys..right this is my first post on here...i hope i wont get flamed to much as im not acaully a 6/rallye owner..but have signed up to see if i can get any advice / info for my 306...
Just as a quick hello, im basically on several other 306 related sites, and drive a black ph1 D Turbo, fairly well known car on some other sites, have done a fair ammount of work to it engine wise..
Now the reason for signing up, i have recently been pushing things quite hard (hybrid turbo, front mount and lots of fuel pump changes and piper cam makes this very hard to overdo lol...) and basically its thrown a rod out the block...now, alot of people are saying ive just had some freak bad luck, as the xud9 cant take alot of abuse, but i dont want to rebuild it, to see the same happen again.
It would appear that was acaully failed, was the bolts holding the rod to the crank...now what im after, is to see if i can get hold of some arp bolts for this, does anyone know if the bolts are the same on a gti6/s16 as on an XUD?
And does anyone have any advice on how i can avoid this happening again!
Thanks for your time, and a few pics just to show you the car in question..
Posted 10th Nov 2009 at 22:52
was it a DHY?
Posted 10th Nov 2009 at 23:07
darrenjlobb
No...d8b...so shud be safe from dodgy rods in the first place right?
Posted 10th Nov 2009 at 23:49
Well, until you try putting 30psi of boost through it, yes..
Posted 10th Nov 2009 at 23:54
what phill said Laugh my ass off
I think it was dodgy rod bolts not rods that affected the DHY, though my brothers one is on 160k+, but has been serviced very well and is not tuned.
Posted 10th Nov 2009 at 23:56
darrenjlobb
Ive seen people put 65psi thro these things tho...and seem to go on and on... so does anyone know if there are some arp bolts that will fit?
Posted 11th Nov 2009 at 00:01
Yeah, but they're dropping the static compression so far the car has about as much pull as a pensioner in a miniskirt until it finally comes on boost, and shocking fuel economy to boot, as the mixture has to be immensly rich low down to get it to light off.
Posted 11th Nov 2009 at 00:07
c_j_m
Love it Phill.
Maybe try the HDi bolts as they use the same cranks as the XUD's and they can take ~240bhp standard.
Posted 11th Nov 2009 at 00:24
vittesse_tuning
seen a 1.9 td running 100bhp nitrous jets and 100bhp propane jet (extra fuel) with 45psi boost on standard bottom end with no problems. couldn't someone measure a 6 bolt for the guy. or anyone got an engine parts book should be listed in there.
custom carbonfibre and fibre glass parts. 07513059320
Posted 11th Nov 2009 at 00:31
XUD, DW and XU use the same bolts as it happens.
Posted 11th Nov 2009 at 00:42
jimmyrallye
that car looks sweet , what sort of bhp wos you running before it went bang ?
Posted 11th Nov 2009 at 00:53
If you search on here you'll find some info from Rich_W about ARP bolts being a bit crap - he uses something different on his 400BHp charged engine iirc
Its great getting all this power out of them but are they a tractable engine you can use everyday and not just light up the front wheels? I would be tempted to get a bit more power out of my 1-9 in my 406, but I don't want it to be too on/off power.
Posted 11th Nov 2009 at 02:28
darrenjlobb
Ok, pulled the engine out this evening, and didnt really have time for examination, but can clearly see in one of the huge holes in the block, that the big end is still on the crank, so the bolts did NOT fail...conrod has snapped in 2...faulty rod?
Possible a bad bearing could cause it over time?
To much power acaully able to cause this from it?
Posted 11th Nov 2009 at 03:01
Nont so much power as revs + shock impacts from the diesel combustion, have you been over-revving it?
Posted 11th Nov 2009 at 04:08
darrenjlobb
What do consider to be "over revving it", i dont genrally rev it past 4500rpm... but it will hapilly pull to 6k with the gov shimmed and the piper cam....
Posted 11th Nov 2009 at 04:41
Well, I would say 6krpm on diesel pistons with high compression and lots of boost might just have helped it on it's way then, rpms have a massive influence on rod stress.
Can you get a picture of the rods?
Posted 11th Nov 2009 at 04:50
I think you've found the reason why most diesels make loads of torque at 1500-3000rpm and don't rev past 4.5-5k as standard LOL
wonder what the dynamic compression is like with 21.8-1 and 30 psi of boost?
Rich only runs 1 bar for 400 bhp right? at about 8.5-1?
Posted 11th Nov 2009 at 15:27
fletch
Track Head
He originally ran 1.35bar at 9:1 but with some beefy forged rods.
Think hes running a little more boost now on the bigger 'charger.
Posted 11th Nov 2009 at 15:35
rich_w
Connecting-rod loads - particularly big-end bolt loads -are more a function of RPM than power. The tensile force on the big-end bolts increases in relation to the square of the RPM I think.
For example, if you increase your rev limit from 7000 by 10%, to 7700, the tensile force on the big-end bolts increases by 21%.
I would need to check a book at home but I think that's right, and gives you an idea of what over-revving does to rods.
Having said that, your big-end is intact, so I wouldn't say over-revving is the problem.
Does the big-end still spin freely on the crank, or is it seized / bearing damaged in some way?
If it's seized, the big-end bearing has failied, which would have pre-empted the rod snapping.
If the big-end bearing is OK it will of probably snapped due to fatiguing over time, caused by the shock loadings from the extremely high cylinder pressures, and the 'diesel knock' style combustion which isn't particularly smooth.
Smile
Contact Details:
07732 822546
Posted 11th Nov 2009 at 16:44
robthe6
a nice helpful answer from rich_w thanks rich!
told you darren there is alright fella's on here Smile
1997 ph1 bianca GTI6 - The looker
1996 ph1 Sigma GTI6 - Dead Sad
1999 Red Rallye - The Daily
2005 Nissan Navara D40 - Family car
1968 Mustang Coupe - The dirty little secret
Put ya foot down, put ya foot down we'll loose em easy!
Posted 11th Nov 2009 at 17:39
darrenjlobb
The bearing seems perfect...just snapped in 2...
Stuck with what to do, whats the point in just building it up agen on a new block, itl just happen agen...
Posted 11th Nov 2009 at 18:37
fletch
Track Head
Presumably stonger conrods and bolts are the way to go?
What sort of budget you on? Might be cheaper to break the car and buy a GTi-6?
Posted 11th Nov 2009 at 18:41
darrenjlobb
Lol, if you knew me, you would know that getting a 6 isnt an option Razz
Posted 11th Nov 2009 at 18:43
fletch
Track Head
30Psi through a XU10J4RS goes a lot quicker Whistle
But seriously, forged rods and bolts, uprated bearings, and if youre feeling flush, lower compression forged pistons ready for some more boost?
Posted 11th Nov 2009 at 18:45
rallyestyle
Nice thread this, good to see no flaming going on, i suspect that is however to do with the excellent first post Thumbs up
Just Drive It
Posted 11th Nov 2009 at 18:50
