Author Subject: Creaking from beam when cold
tommy
I'v got a slight creaking coming from the rear beam of my Xsara when I first get in it on cold mornings, goes away after 30 seconds of driving though. Is this likely to require a rear beam rebuild or could it be something less serious? I seem to recall my old one did it a bit over winter but then was fine over summer.
Xsara VTS - Warm and dry
Honda CBR600F3 - Cold and wet but...0-100 in 7 seconds Big grin
Team "I had a TZR125™"
Posted 10th Nov 2009 at 19:43
if it is the beam then its likely to be donald ducked already if it squeaks.
Posted 10th Nov 2009 at 19:47
tommy
Would that not be all the time though? It's fine when you're driving...or am I clutching at straws hereLOL
Posted 10th Nov 2009 at 19:59
Does it do it with the handbrake off?
Posted 10th Nov 2009 at 20:04
tommy
Yep, it does it every morning as I roll back off my drive.
Posted 10th Nov 2009 at 20:08
Jack up the rear of the car and see if you have any movement in the beam. Doesn't sound promising though Sad
Posted 10th Nov 2009 at 20:10
jungle jim
That is what mine sounded like. It progresses to squeaking everywhere.
200+ secret squirrels hiding under the bonnet with 4 wide mouth frogs...
Posted 15th Nov 2009 at 03:45
biotaw1
Check this isn't the handbrake squeeking a bit if it's binding as you back off your drive Wink
Posted 4th Mar 2010 at 20:59
darkgti6
biotaw1 wrote:
Well, it seems to have stopped doing it nowBlink I guess the weather has warmed up a bit so maybe it's that? I'll have a look at it tomorrow though.
The bearings are probably knackered mate!
How old is your car now? Approaching ten years old? 80k plus miles?
Start putting a bit of money away each month for a rebuild. The car will still be driveable for the time being. Mine got through an MOT and the bearings on the offside had been ground down into a smooth paste!LOL
Team Peugeot Sport 308 Gti�
Posted 15th Nov 2009 at 17:42
craigy_87
if i keep my foot on the brake when my "big" mate gets out the car, then let it off after he's out i sometimes get a small creak but its then only. this sound like the beam or something else
Posted 15th Nov 2009 at 18:00
tell the fat lump of butter to diet then.
problem solved
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 21st Nov 2009 at 18:48
ant_kernow
problem solved
LOL
team umpalumpa.
Posted 22nd Nov 2009 at 03:43
oecken
Would this come up on the MOT? mine just went through fine, and the beam is knackered! Neg camber on both wheels, has been this way since the last mot Whistle
(Yes getting it sorted in the new year lol)
Posted 24th Nov 2009 at 02:18
I get a creaking from the rear end of the car when the handbrake is on a bit and car starts moving. If I pull the handbrake up a bit more it stops.
Is my beam fooked?
Posted 24th Nov 2009 at 02:44
lwgti-6
Is my beam fooked?
Will more than likley be the rear pads rubbing on the disks if the handbreak isnt up far enough. Mine does the same, another click sorts it out.
EX Bianca 6 owner,
Now drives: Octavia vRS
Posted 24th Nov 2009 at 03:03
