displaying posts 1 to 25 of 37
Author Subject: ABS Removal on Track Car
shakey
Done a quick search but found nowt, anyone removed it from theirs ? If so fancy doin a quick FAQ.
Cheers, Steve
Posted 28th Oct 2009 at 01:30
chris with a pug
this is how I did it.
Not sure if you want to keep the ABS for road use
Posted 28th Oct 2009 at 01:33
shakey
No just track use. Guess it's a bit easier with the engine out the way.
Posted 28th Oct 2009 at 01:36
mr swampy s16
**BAD SELLER**
If you intend to mot it and the car was fitted with it you need it working.
Or a friendly tester.
Would require new lines or at least parts of lines to join up from mc to the rest of system.
Could then remove the sensors, abs pump, etc
Posted 28th Oct 2009 at 01:38
if it is not there it can't be tested, it doesn't need to be there atall for the mot if it was born with it. if you have it, but it's broke, then that is when it's a problem (what i was told by the garage)
i routed all new pipes from the MC to the calipers via a bias valve and did away with the valve underneath
had the front MC port splitting down to a T piece, going off to both front calipers
had the rear MC port going to the inside, to a bias valve, out the back and to another T piece; two lines to each rear caliper.
Posted 28th Oct 2009 at 01:43
chrisd306
What rikky said, as weve had this with a few cars at our garage
In my garage just now
& Audi Q5 S Line
AX stock rod & Saxo Stock rod
Posted 28th Oct 2009 at 02:21
shakey
Sh*t, sounds a bit more involved than I thought. Did you do your own Rickky or a local garage ? I live in Wales but work in central Manc. Oh and how much did all that cost ?
Cheers Steve
Posted 28th Oct 2009 at 02:37
mr swampy s16
**BAD SELLER**
Yeah he did it all.
I supplied all the lines for him and have done for a couple of others on here and other forums
Posted 28th Oct 2009 at 03:19
pete_rallye
Yeah, do as Rikky says, thats how I did it. I'd keep the brake servo too, I have 2x master cylinders and no servo and the brakes don't feel half as good.
Cost wise you should be able to do it for around
Lap of the 'ring
Posted 28th Oct 2009 at 04:41
I re-plumbed the back half of my ZX (from bottom of bulkhead right back to the calipers) for less than a
Posted 28th Oct 2009 at 04:48
joevts
err... just take the fuse out?
Posted 29th Oct 2009 at 00:49
mr swampy s16
**BAD SELLER**
Doesnt reduce the weight though does it?
Posted 29th Oct 2009 at 00:56
loads of weight to be saved ditching the abs and pipes. you will be suprised. get all the loom and everyhing out from underneath, bloody loads of it
Posted 29th Oct 2009 at 01:18
shakey
Like I said, anyone fancy doin an FAQ or even better doin the job for me ?
Posted 29th Oct 2009 at 03:00
miles
It's easy, Remove pump and wiring which runs under the car and remake brake pipes to suit.
Can;t really say much more than that
www.pugracing.com
Posted 29th Oct 2009 at 03:48
easy to do yes but fiddly routing pipes and whatnot, not hard though by any means. you will get very messy too removing the wiring and old pipework [or i did!]
Posted 29th Oct 2009 at 03:58
Looking forward to doing mine Dry
Posted 29th Oct 2009 at 04:00
walk in the park for someone of your mechanical calibre Whistle
Posted 29th Oct 2009 at 04:15
Thanks, I think? Unsure LOL
Posted 29th Oct 2009 at 04:17
yeah you'll be fine. i know you have hand problems but you'll get there
Posted 29th Oct 2009 at 04:20
What's this ABS malarky then?
Posted 29th Oct 2009 at 04:21
it's that metal block that has a load of outlets on it, you use it for propping your block upright when you remove the bottom mount.
Posted 29th Oct 2009 at 04:24
bono
I got rid of my ABS.
I thought, why would you want Anti-Braking-System?
///M5
Posted 29th Oct 2009 at 04:26
Hand problems? Other than chronic wrist cramps (I'm single) I have no idea what you are talking about! Wink
just fooling you bruvva LOL
Posted 29th Oct 2009 at 04:27
