displaying posts 1 to 25 of 35
Author Subject: clutch judder!! FIXED!!
cabbymeg
Hi all please help!
I've had a judder from the clutch for a while now. Mr Clutch fitted a new clutch last year, so I took it back to them under guarantee.
They replaced the clutch FOC just over 2 weeks ago and it was fantastic, much nicer to drive etc. Now since then the judder has returned and is now just as bad as before it was replaced.
It's had a new clutch, clutch cable and lower/upper engine mounts.
What the hell could it be? Flywheel maybe?
Posted 4th Dec 2009 at 20:29
miles
Clutch, you pay peanut's you get monkey's I;m afraid, Take A Valeo clutch into them and get them to fit that.
www.pugracing.com
Posted 17th Oct 2009 at 02:06
cabbymeg
Sorry but I don't think it'll be the clutch. It's had an LUK one fitted which are good clutches, and anyway even a cheap clutch will last more that 2 weeks gentle driving don't you think?!
Posted 17th Oct 2009 at 02:29
bobdylan_55
arnt LUK them ones off ebay which the springs fly out of after like 80 miles?
309 GTi6-T
Posted 17th Oct 2009 at 02:42
Nah LUK are normally good.
Do you deffo know that it was a LUK one fitted? Could be an oil leak on to the clutch plate from somewhere like the rocker gaskets. Also check that the box hasn't come loose from the engine.
A cynic might say you've had two clutches from them and they have both gone wrong.
Posted 17th Oct 2009 at 02:50
cabbymeg
Hmm, let me think about that .........
http://www.luk.co.uk/
cabbymeg
Definately an LUK clutch, I was there when it was delivered and unpacked.
If there had been an oil leak it wouldn't have been covered under warrenty so should be ok, I'll check the 'box is tight tomorrow but I think it will be.
Can't think what else could cause it though!
Posted 17th Oct 2009 at 03:01
Broken springs in the clutch plate, sticking fork or cable.
Posted 17th Oct 2009 at 03:04
mechanical_repairs
Luk clutches are normally ok,
you may have high spots on the flywheel or a rear main oil seal leak and after a while these are the causes to your issue, you need to have the face skimmed on the flywheel itself to remove the high spots and check the seal whilst the flywheel is removed, then refit the clutch etc
Carl
Posted 17th Oct 2009 at 03:29
cabbymeg
Carl
That was the lines I was thinking. Any ideas on cost and places to get the flywheel skimmed? Would I need to put another new clutch in or should this one be ok?
Posted 17th Oct 2009 at 03:34
mechanical_repairs
Carl
You would be looking at the cost to remove and refit the box, most engineering firms can skim a flywheel for you. I would say on average
Posted 17th Oct 2009 at 03:44
Carl
Posted 17th Oct 2009 at 04:03
cabbymeg
quote:
[quote="mechanical_repairs]You would be looking at the cost to remove and refit the box, most engineering firms can skim a flywheel for you. I would say on average
Posted 17th Oct 2009 at 04:08
LUK make sachs as far as i know.
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 17th Oct 2009 at 16:24
mechanical_repairs
The new clutch will start to pick up on the hotspots on the flywheel or if its oil related will start to get covered in it.
Carl
Posted 17th Oct 2009 at 21:02
gtisid
did they do the cheeky thing and just replace the plate ? or did they replace the cover too?. i had this a few years back and with a new cover and clutch the problem was solved. if not your flywheel needs skimmimg as carl mentioned. better still put one of the lightened ones in
pugless
Phase 1 GTI 6 1996-1997
Subaru Impreza GB270 2007-2008
rare spiderman comics
same day international courier
Posted 18th Oct 2009 at 12:46
cabbymeg
Bit more info on this guys.
Now the temperature outside has dropped the clutch judder has improved, but only when the car is cold. 5 minutes or so into a journey and the problem starts again, steadily getting worse.
Does this shed any more light on it? I'm going to rip it apart this weekend so fingers crossed i'll sort it!
Posted 25th Nov 2009 at 16:16
will130787
gotta be an oil leak then surely? The oil gets warm and seeps through somewhere....
Ex Astor 6 owner Sad
Also an Ex owner of a Bianca 6 Sad
Now an ex owner of a 2005 9-3 2.0T 210bhp Aero Swedish Saloon thing!! Soon to be 250bhp.... Superman
Now driving Mk5 Golf GTTdi, mile muncher
But still live for the 306 Ninja
Posted 25th Nov 2009 at 19:53
andrewrallye
There is the possibility that the clutch/gearbox splines are dirty, it depends how meticulous the mechanic was when he fitted the clutch. This may be stopping the plate from fully disengaging and breaking drive. Clutches are made and lifed as a unit these days, generally a three piece kit, plate, cover and bearing, and sold as that so I would suspect that they fitted the whole lot. One other thing, a bent input shaft could cause the same thing but the fault would be there all the time.
E reg 205GTI non sunroof maybe for sale m.o.t'd ideal rally, trackday car, also have 6 engine and box available
Posted 27th Nov 2009 at 15:11
cabbymeg
Right, i'm just in the middle of removing the box and i've noticed LOADS of play in the clutch arm, where it goes down into the box. Could this be the cause?
Posted 27th Nov 2009 at 17:59
jaydog81
You mean the arm that the cable connects to.
If so most have about 1" of play dude
*jay81.
Phase 2.5/S-99
Team i live for working,Paying bills and funding my hobbies. I wish my life could be just living for a pink "I love the 6 sticker".Laugh my ass off
Posted 28th Nov 2009 at 02:44
andrewrallye
Do you get any vibes through the pedal?
Posted 28th Nov 2009 at 02:48
cwspellowe
I was getting a lot of vibration in the pedal and it turned out the sheath on the cheapo clutch cable i'd fitted had melted so it wouldn't return properly.
Just a thought..?
Bye bye Sundance Kid Sad
Posted 28th Nov 2009 at 03:11
james naylor
mine does exactly the same and its cos my flywheel is warped!!!
Posted 28th Nov 2009 at 04:06
anthony_p_59
i've got a slight judder too, but it just comes and goes as it pleases, i've put it down to the general french engineering excuse, just like my squeeling heater fan LOL
Posted 28th Nov 2009 at 05:04
