Author Subject: my gearbox is leaking
ken
when i done the wheel bearing on my car my mate noticed i had a gear box leak!
i have noticed more and more now that it cruches going into gear and sometimes wont go in!! i know annoying.
the leak isnt soming from where the driveshaft is its the other side by the block! im unsure whether to buy a new gear box incase the syncro mesh is fooked or to find patch the leak up!
but there is alot of oil around the gearbox that side!
do you reckon the bolts have come loose and need tightening or any other reason??
cheers ken
Team Black Rallye Big grin
xbox live - Xx 7 kenny 7 xX
Posted 16th Oct 2009 at 17:02
Rich E Forum Admin
Most likely culprits are the driveshaft seals and the selection arm seal.
Fix the leak and top the oil up and it will more than likely be fine, but if you keep running it while it's low on oil then you could damage it badly.
Posted 16th Oct 2009 at 17:29
ken
ok cool cheers bud!
Posted 16th Oct 2009 at 19:21
condieboy
Just incase it is a driveshaft seal, I had the N/S seal go on mine and it was ~
Ecosse Dyno Day 31/10/09
175.2Bhp & 149lb/ft Big grin
Posted 16th Oct 2009 at 19:29
ken
ok cool! cheers guy
Posted 19th Oct 2009 at 12:31
jimmy_boy
GTI-6 & Rallye
Rallye gets sideways in the wet at Snetterton Ninja
Posted 4th Nov 2009 at 18:14
jimmy_boy wrote:
Posted 4th Nov 2009 at 20:18
jib
jimmy_boy wrote:
Posted 4th Nov 2009 at 20:21
+VAT unless they'll give you any discount in which case its about
Posted 4th Nov 2009 at 20:25
craigy_87
ya
Posted 4th Nov 2009 at 20:45
jimmy_boy
jimmy_boy wrote:
GTI-6 & Rallye
Posted 6th Nov 2009 at 02:01
craigy_87
could you have damaged a seal when doing the work needed to change the wheel bearing?
Posted 6th Nov 2009 at 02:08
khj100
Yes. To change the bearing you'd have to remove the driveshaft. And if you mash the seal up when removing/replacing the shaft, it'll leak. Only if you're not careful though.
Posted 6th Nov 2009 at 02:25
