Author Subject: Bounce around corners
lotek
i went around a roundabout last nite , not overly fast but accelerated round it a little.
the car started bouncing around the last part of it?? was quite funny and annoying at the same time..
i have koni adjustables with eibach on the front and gmax shocks on rear
the car is stripped and the koni are turned up pretty much full , i think it adjusts rebound.
what is causing it?
Posted 15th Oct 2009 at 17:18
Either:
a.) dampers are set too hard and it jacked down onto the bumpstops.
b.) One of the dampers has died.
c.) It was a bumpy roundabout.
Posted 15th Oct 2009 at 17:17
lotek
im hoping the dampers havent died,
the roundabout wasent amazingly smooth , but it has done it before, usually when cornering hard- round roundabouts lol
Posted 15th Oct 2009 at 17:22
I would also suggest that you have mismatched dampers front to rear - the front will be way too hard in relation to the rear. The rears aren't very good (lets face it), if warmed up could well be worse than standard damping. What ride height?
Posted 15th Oct 2009 at 17:56
lotek
im on -40 front and aparently -60 rear, but the whole car has rose like an erection since stripping it lol
Posted 15th Oct 2009 at 19:02
lotek
went for a drive earlier and softened the fronts a little it felt a bit better but the rear is still very twitchy,could do with a hybrid arb me thinks , what rear shocks should i use?
Posted 15th Oct 2009 at 19:04
Whistle
Posted 15th Oct 2009 at 19:25
lotek
phillipm wrote:
Whistle
haha apart from fox ! lol im not ver flush at the moment, i gt to sort wheels,disc, beam , and handling, should just buy a new car really haha..
phill did you find any of those connectors for brake lines?
Posted 15th Oct 2009 at 19:27
Whats wrong with the beam? Worn mounts?
The hybrid rear arb won't really help you until you get the damping issues sorted - trust me on that one! Run your front shocks at say halfway and get the beam raised a tad. Wheels and brakes can wait until you get it to handle right Thumbs up
Posted 15th Oct 2009 at 19:38
Not until I get up to the workshops this weekend Smile
If it is jacking down at the back, it'll be hitting the bumpstops early due to the back being lower than the front, either lift it up slightly, or run the rear shocks slightly softer, and see what happens
Posted 15th Oct 2009 at 19:49
lotek
the rear is actually sitting really high since it was stripped, and i have sold beam mounts.
its probably the dampers , the rears are not adjustable therefore are mismatched to the fronts, i will keep playing with front setting till i get a good medium.
may even start carrying a spare again.
Posted 15th Oct 2009 at 20:08
lotek
no what i ment was if you have a lightened car you need softer suspension as there is not the weight there to make the suspension work. all that happens is the car hops and skips about bouncing instead of the suspension absorbing the bumps
..Taken from xsara forum.
Posted 15th Oct 2009 at 20:12
Yeah, but you'll have more than enough weight to worry the standard torsion bars and crap dampers. They have stiffer TBs in the xsaras as well. Why new beam in your previous post?
Post a photo of the rear wheel clearance to the arch Thumbs up
Posted 15th Oct 2009 at 20:42
lotek
my beam is making a racket.. imagine holding a box of sockets and shaking them side to side, its a bit like that , its annoying , and ever since i fitted the solid mounts.
its the 2nd beam ive been through haha should of just re-built the 1st, il go get a photo now.
Posted 15th Oct 2009 at 20:50
I'd check a couple of things then - that the exhaust isn't hitting heat shields and the beam and that the arb end plates are on correctly - thats what normally does it on my car.
Have you checked the mounts are tight?
Posted 15th Oct 2009 at 20:54
lotek
lotek has attached the following image:
Posted 15th Oct 2009 at 20:56
lotek
Posted 15th Oct 2009 at 20:57
al4x
you could swap it back to standard, rumour has it they were one of the better handling cars out of the factory Wink
Posted 15th Oct 2009 at 20:59
lotek
i have checked the mounts, also when im slowing and get to a slow speed i get a horrible noise from the rear but only when braking??? recently got worse .
low brake pads? wheel bearing?
ride height looks fine.
if you have any standard dampers to hand I'd stick them on at the back.
Posted 15th Oct 2009 at 21:37
lotek
the only standard dampers i have are foobard.
pads are fine, the wheel bearing is a possibility though.
im thinking just to get a vts beam- more camber suppoesedly and 21mm bars. or bodge a partner beam on to car , lol that fecker wont keep breaking!
Posted 15th Oct 2009 at 22:00
Just a thought, with no weight in mine it didn't look that high and it was only a 20mm drop. Strange!
Posted 16th Oct 2009 at 00:14
lotek
lol i know it looks like its on stilts! lol
Posted 16th Oct 2009 at 07:51
106lad
with no weight on mine at the back its arse rises up like Jenna Jameson waiting to receive
Bianca White Ph2 306 GTi-6 Sold
Phoenix Yellow E46 ///M3
E36 M3 Imola Individual GT2
Team: 321bhp
07/11/08 - Pete Sims, gone but not forgotten, RIP
Posted 16th Oct 2009 at 16:05
