Author Subject: reducer ring..high-low boost
steve_l_gti6
hi there if i high boost my car and put the reducer ring back in, will it make it 250-260bhp? And if so, will it feel the same as if i low boost my 6?
Posted 9th Oct 2009 at 04:57
I'm not a schitsophrenic.
But I am.
Posted 9th Oct 2009 at 05:09
steve_l_gti6
But I am.
was just a question filipe.
Posted 9th Oct 2009 at 05:20
smegal
Pretty much, It may make a bit less because it would be low comp.
Ex SC-6
Now in a Megane R26
Posted 9th Oct 2009 at 06:03
steve_l_gti6
would i need to change injectors or run low map??
Posted 9th Oct 2009 at 06:04
steve_l_gti6
or ca i use same injectors and same ecu, just a thought?!
Posted 9th Oct 2009 at 06:05
smegal
I guess that when you are running the high boost in you just run with the low boost injectors/map then upgrade when you are ready for mapping. Hopefully zac or rich or someone will come along soon and will tell you. I am only guessing.
Ex SC-6
Now in a Megane R26
Posted 9th Oct 2009 at 06:08
steve_l_gti6
thanks for the reply anyhow mate, wil wait and see if someone can verify or put right your answer.
cheers
Posted 9th Oct 2009 at 08:17
fletch
Track Head
What injectors are you using? 440 ccs? as said you are running low compression for which there is no low boost map available. You could switch to a low boost map but as you are running ~9:1 compression as opposed to ~10.8:1 standard it might be a little sluggish.
Posted 9th Oct 2009 at 12:19
chrisd306
im going to be running about 230ish i think as going low comp but staying low boost for now, low boost map will be fine as thats what rich has done for mine. i will go for larger injectors and larger boost pipe and cooler, although i might get rich to do me a diff map, and diff restrictor so i can run at 280ish safely, to be honest i just want to run again!
In my garage just now
& Audi Q5 S Line
AX stock rod & Saxo Stock rod
Posted 9th Oct 2009 at 12:41
farmer
I don't understand why you would want to only run 'low' boost when you have done the extra work required to go 'high' boost Dunno
If i had gone to the effort of changing the pistons and rods and bearings etc, and have the larger boost pipework then I certainly would be running without the restrictor ring!
If you only want 250~ bhp then dont spend the extra money on the bits not needed!
Long live the Sigma 6 Big grin
Team Phase 1 supercharged
XBL ID: farmer uk1
Posted 13th Oct 2009 at 01:48
steve_l_gti6
just wanted to run it as if it was low boost then go high boost when got bored and would be a cheaper way than if i went low boost then done all the work to go high boost!just a thought.
Posted 14th Oct 2009 at 06:15
